Old 01-16-2006, 07:37 AM
WikidPete WikidPete is offline
WikidPete is off the scale
Finally finished the install of the Air Horn. Thanks to fourfourto for the tips from his POST Here.
Installing a Momentary Switch for the Horn. This is what I came up with for a nice flush look.
Old 01-16-2006, 07:38 AM
Drilled a hole in the blank for the switch
Old 01-16-2006, 07:41 AM
Another PIC Assembled Switch with the blank.
Old 01-16-2006, 07:42 AM
Installed back into the Console. Rear View.
Old 01-16-2006, 07:43 AM
Front View
Old 01-16-2006, 07:45 AM
Front View Close Up
Old 01-16-2006, 07:46 AM
And here are the Air Horns. Much Better than the original.
Old 01-16-2006, 07:57 AM
The compressor is mounted behind the Left Headlight.
Old 01-16-2006, 12:35 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
Whoa! That's one (two) serious air horn setup! I feel sorry for the person going slow in front of you!
Good job on the installation. Nice and clean looking.
____________________________
Old 01-16-2006, 12:41 PM
fourfourto's Avatar
Nice ! I used the other switch at radio shack it had a bigger button and I removed the blank .I did use same quick connect (for rc car)The switch you used has a nice clean look.
Also I was to lazy to remove grill I just forced the bigger horn through the opening in the grill.
This horn is a inexpensive option to those high priced horns.
My wife blasts it all the time .she's horny.
Heres the switch i used. I thought it matched my lighter so I went with that one.
