Old 09-10-2007, 04:28 AM
Tex_h2's Avatar
Tex_h2 Tex_h2 is offline
Default Tire Size
What is the largest tire size you can go with stock rims/suspension?
Also who has Nitto or Toyo?
Pics as well
Old 09-10-2007, 05:15 AM
jmsspratlin's Avatar
Default Re: Tire Size
Pics as well
I run toyos now, however not stock rims
Old 09-10-2007, 05:57 AM
brad_p's Avatar
brad_p brad_p is offline
I am wondering the same thing, i am getting 20x10's and want to know the biggest tire size i can get without having rub issues. would a 37x13.5 be good or would i need to adjust tourtion bars?
Old 09-11-2007, 11:49 PM
IRA51's Avatar
IRA51 IRA51 is offline
37-13.50x17 will work with just a slight rub in front at or near full lock,if you have rear air suspension you will need to modify the ride hight sensors. if you crank the T bars do not expect a nice smooth ride anymore,and you will need to have it aligned. I have the Toyo open country MT's in 35-1250x17 and no rub no problem and they preform very well off road . many here run the 37-1350x17 and are happy so it will work .
A government big enough to
you have.
-- Thomas Jefferson
