09-11-2007, 04:25 AM
Does anyone have the instruction list for the tail lamp guards
The ones that they sell on the somo the tail lamp brushguards i seemed to have lost the instructions. If any of you have that sheet, could you either scan it into the comp. Or fax it. If your going to fax it send me a PM and ill give you my fax number. Also i know im asking a lot today guys, jsut tomorrow im finally getting them installed, and would liket o bring the instructions to make the guys' work a little easier.
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
09-11-2007, 04:59 AM
Re: Does anyone have the instruction list for the tail lamp guards
You are way, way overdoing things. Do you have OCD? Any tech can install these without instructions. Take deep breaths and R_E_L_A_X.
09-11-2007, 05:02 AM
hahahhahaha, i know they can install em without the instruction duh, believe me if i had OCD youd know it, i just thought to make the guys' life easier. but they threw a 3.5 inch lift on my friends rig no problem so if they cant instale these there idiots. alright if they do get em on tomorrow im trying to squeeze in minus an appoinment ill get some pics up
2017 VW Jetta S
/''T''|[___|___]
09-11-2007, 04:09 PM
Open up the rear door. In the area of the tail lights in the door jamb, you will see 2 screws, Take out the screws and GENTLY pull the tail light cover off.
The rest is self explanitory, install them with the new guards. Done.
09-12-2007, 12:35 AM
Alright took em to get installed they came out sick!!!! I'm at dinner now I'll put up pigs as soon as I get home
2017 VW Jetta S
/''T''|[___|___]
09-12-2007, 02:36 AM
09-12-2007, 02:54 AM
aight tower shoulda read the last post its already installed got it done after school. And your idea wqould work anyway becuase the dealer refused to install it because i didnt buy the part from them. Check out the pics thread section theres a couple before and afterpics
2017 VW Jetta S
/''T''|[___|___]
09-12-2007, 03:10 AM
WOW! And you did it all by yourself? And without an instruction sheet!! Congratulations!! Do you have pics of the installation procedure? How long did it take you? Did you need to take breaks? What tools did you need? Did you have them on hand or did you need to buy/borrow them? Did you keep an eye on that pesky parking break cable? (He's a wild one!) How many times did you need to use the toilet? #1? #2?
Seriously, congrat's. You now have the satisfaction of knowing that you did it yourself.
09-12-2007, 03:22 AM
ok the side bars still havent done i need to go buy tools. As much as i would like to answer all your questions. I cant cuase i took it to this place to get installed
2017 VW Jetta S
/''T''|[___|___]
09-12-2007, 03:26 AM
OMFG!
09-12-2007, 03:47 AM
i knew your answer would be somewhere along the lines of that.
2017 VW Jetta S
/''T''|[___|___]
09-12-2007, 03:20 PM
When I installed my tail light guards, I had to loosen the screws behind the tabs on the rear bumper to install the bracket that goes beneath the guards. Installing the one on the driver side required closing the rear door half way in order to get the tail light guard installed without scratching the paint.
I assume some are different than others so it could very well require the instructions, I didn't know there were screws behind the tabs on the rear bumper, why would I?
Rack 'em.
