Old 09-13-2007, 02:42 AM
iccon's Avatar
iccon iccon is offline
iccon is on a distinguished road
Unhappy Check oil message
my check oil message keeps coming on but the oil level is fine and even a bit high any suggestions, oil life is at 75%
Old 09-13-2007, 03:18 AM
Default Re: Check oil message
NOT SUPPOSE TO BE A "BIT HIGH" when did u change it last? how much did you put in? the capacity is 6 quarts no more and no less, what weight are u running???
Old 09-13-2007, 05:19 AM
iccon's Avatar
I just bought it 2 months ago not sure when last oil change was done
time for a new one I guess then see waht happens.
Old 09-13-2007, 06:46 PM
yeah 6 quarts 5w30 and new filter and than reset
Old 09-14-2007, 12:00 AM
mikejr's Avatar
mikejr mikejr is offline
is the oil looking foamy or anything out of the ordinary? its worrisome if its high and you didnt add too much that something else is getting into the oil...ie coolant. I'd change it and the filter and see what happens.
2009 H2 Silver Ice LE
Old 09-15-2007, 01:04 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
I have seen some cases of the low oil level sensor sticking, especially if the oil was drained with the key on. next time it happens just tap on it lightly with the handle end of A screwdriver, its located on the right side of the oil pan.
