09-13-2007, 11:13 PM
my a/c quit
Hello,
I have on 03 H2 with 44k miles. My ac quit blowing cold yesterday. I was wondering if there was any issues with this or if i just need to take it in and get it charged. It blows hot. Can't think of anything else that it could be than just needing a recharge.
thanks for you help
Darin Kaiser
09-13-2007, 11:55 PM
Re: my a/c quit
Check some of the obvious things first before paying for a recharge such as the fuse for the compressor (its got an electronically controlled clutch) and then check to see if the compressor is even engaging
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
09-14-2007, 01:11 AM
Re: my a/c quit
check to see if the belt is still on the pump. My tension idler **** the bed and tossed the belt off.
09-14-2007, 01:15 AM
Re: my a/c quit
What they said, check compressor engaging first
09-14-2007, 02:42 AM
Re: my a/c quit
are the other functions of the hvac control panel working correctly? I'd try the other things mentioned on the thread.
2009 H2 Silver Ice LE
09-14-2007, 03:16 AM
Re: my a/c quit
Yep is all works fine, just doesn't blow cold. The belt looks fine. I check the fuse on the side of the dash. Is that the fuse that you guys are talking about? just thought that is was odd with only 44k miles, but i guess it is 5 years old. Thanks guys for the tips, I will check them out.
dk
Darin Kaiser
09-15-2007, 11:33 AM
Re: my a/c quit
If belt is on and pump is pumping when engaged , try adding some freon. Its not freon anymore , its N-12 or something. You can buy a can at Napa for $15. The can has a hose that snaps onto your condenser line , then push top of can and fill system. If a/c doesnt blow cold after that take it to a shop. Only do this after you have checked the fuses , reset the brain , and checked the belt is on. doug
