09-14-2007, 04:09 AM
OEM Up tops adjustment
I heard that one can adjust the height of the beam on the OEM up tops. How would I go about doing this?
09-14-2007, 04:33 AM
Re: OEM Up tops adjustment
You were supposed to get a tiny little flat wrench that will slide into the sides and turn the nut.
09-14-2007, 11:55 AM
Well F***! I definitely did not get that. Can you take a a pick and post it? I may be able to jerry rig it.
09-14-2007, 02:20 PM
Originally Posted by Hunner
You were supposed to get a tiny little flat OEM beam height up tops wrench that will slide into the sides and turn the nut.
WTF???
09-14-2007, 03:49 PM
?? Are you talking about the crossbars?
09-14-2007, 06:04 PM
beam   /bim/ Pronunciation Key - Show Spelled Pronunciation[beem] Pronunciation Key - Show IPA Pronunciation –noun
1.any of various relatively long pieces of metal, wood, stone, etc., manufactured or shaped esp. for use as rigid members or parts of structures or machines.
2.Building Trades. a horizontal bearing member, as a joist or lintel.
3.Engineering. a rigid member or structure supported at each end, subject to bending stresses from a direction perpendicular to its length.
4.Nautical. a.a horizontal structural member, usually transverse, for supporting the decks and flats of a vessel. b.the extreme width of a vessel. c.the shank of an anchor.
5.Aeronautics. the direction perpendicular to the plane of symmetry of an aircraft and outward from the side.
6.the widest part.
7.Slang. the measure across both hips or buttocks: broad in the beam.
8.Machinery. a. walking beam. b.(in a loom) a roller or cylinder on which the warp is wound before weaving. c.a similar cylinder on which cloth is wound as it is woven.
9.the crossbar of a balance, from the ends of which the scales or pans are suspended.
10.a ray of light: The sun shed its beams upon the vineyard.
11.a group of nearly parallel rays.
12.Radio, Aeronautics. a signal transmitted along a narrow course, used to guide pilots through darkness, bad weather, etc.
13.Electronics. a narrow stream of electrons, as that emitted from the electron gun of a cathode ray tube.
14.the angle at which a microphone or loudspeaker functions best.
15.the cone-shaped range of effective use of a microphone or loudspeaker.
16.Citizens Band Radio Slang. beam antenna.
17.a gleam; suggestion: a beam of hope.
18.a radiant smile.
19.the principal stem of the antler of a deer. –verb (used with object)
20.to emit in or as in beams or rays.
21.Radio. to transmit (a signal) in a particular direction.
22.Radio and Television. to direct (a program, commercial message, etc.) to a predetermined audience. –verb (used without object)
23.to emit beams, as of light.
24.to smile radiantly or happily. —Idioms
25.beam in, Citizens Band Radio Slang. to be received under optimum conditions; be heard loud and clear: They told me I was really beaming in.
26.fly the beam, Radio, Aeronautics. (of an aircraft) to be guided by a beam.
27.off the beam, a.not on the course indicated by a radio beam. b.Informal. wrong; incorrect: The pollsters were off the beam again for the last presidential election.
28.on the beam, a.on the course indicated by a radio beam, as an airplane. b.Nautical. at right angles to the keel. c.Informal. proceeding well; correct; exact: Their research is right on the beam and the results should be very valuable.
09-14-2007, 07:19 PM
OEM off road lights that attach to the roof of my truck. I'm sorry. I guess I should have specified. You see at their present angle of projection they cause a reflection onto my windshield that makes them rather antiproductive. I had heard that one can adjust them up and down. Does anyone know how to do that?
09-14-2007, 07:23 PM
I heard that one can adjust the height of the beam on the OEM lights up top. How would I go about doing this?
fixed.
09-15-2007, 05:09 AM
I heard that one can adjust the height of the beam on the OEM crossbar lamps. How would I go about doing this?
Fissed.
09-15-2007, 05:23 AM
don't matter how they're adjusted they still shine on the windshield.
I've posted here before how worthless they are.
Only thing to do is make some kind of glare shield to keep the light from shinning down, others have suggested it before.
98 ZR-2 Blazer
Ex H2&3 owner
09-15-2007, 10:42 AM
sorry tower. they're not on crossbars. They're actually on the roof. You see the crossbar lights are made by plus1 or Delta. Mine are the Factory ones.
09-15-2007, 07:41 PM
I heard that one can adjust the height of the beam on the OEM roof lamps. How would I go about doing this?
Oops! I was thinking you had an H2. Sorry. My bad. I guess it would help if I read which forum I was on.
09-15-2007, 07:51 PM
Can you fabricate or buy some Shovel, yes Round Nose Shovel heads like on a shovel, but sized for your needs, custom fab or something stock from the landscape supply and remove the handles and weld some tabs and paint and mount them on your system?
Not sure what the stock configuration looks like.
In the early 90s one of my racks came with this kind of mod.
Have you tried a piece of Limo 5% Window tint strip at the top of your windshield?
You can also use a piece of Vinyl UV type vinyl in Black and Black out a Sun Shield at the top of your windshield
We do this on our Race Cars? The Vinyl I speak of is used in Truck and boat lettering, signs etc...
09-17-2007, 01:38 PM
The lights on your roof are dealer installed and they might have an idea how to adjust or a solution to your glare problem
 "We don't do pretty"
