Old 09-14-2007, 04:07 PM
rusty rusty is offline
rusty is off the scale
Default 37x13.50.17 toyo question
Has anyone run toyo oc mt 37x13.50.17 on the stock rim w/air ride and not had problems?
Old 09-14-2007, 04:19 PM
Default Re: 37x13.50.17 toyo question
SEARCH IT, there is an issue i wanna say withe the width??? i may be wrong thou
Old 09-14-2007, 04:28 PM
I did SEARCH IT and found info but all seemed to be on aftermarket rims?
And I saw threads re: modifing air sensor, but not sure if people running Toyo 13.50s(which are 14" wide) are on stock rims, or if i need different backspace?
Thx
Old 09-14-2007, 05:42 PM
Thx
I saw those tires first hand on H2 Bully's rig in Moab. She ended up breaking the air ride sensor (it had been modified) The tires were mounted on stock rims. They looked HUGE. She went home and traded them in for 12.5" wide. You could mount them on a different rim, but imo, they're too wide for a non lifted truck. Good luck.
Old 09-15-2007, 03:31 AM
BradO's Avatar
BradO BradO is offline
BradO is off the scale
I have air suspension and 37's on my H2. They will fit until you flex and compress the rear. Then they are just a little wide and occasionally hit the sensor arm unless you reverse it. I am running those Toyo's currently on a 17in wheel with a -6mm offset which compensates spacing for the wider tire. Otherwise go with a 12.5 wide tire and you'll be fine on stock wheels.
Old 09-15-2007, 08:50 AM
H2 BULLY's Avatar
H2 BULLY H2 BULLY is offline
Just say no to the toyo 13.50 with air ride and stock rims, they will f..ck your truck up. especially if you off road.
T & A RULES ESCALATOR
Kiss my AXLE
Old 09-15-2007, 10:19 AM
RuggedH2's Avatar
RuggedH2 RuggedH2 is offline
Kiss my axle 13.50!
Old 09-15-2007, 04:50 PM
Originally Posted by 03H3
Kiss my axle 13.50!
Old 09-22-2007, 09:53 PM
medihummer medihummer is offline
medihummer is on a distinguished road
does anybody know the offset of the OEM rims of the H2?
I can not find any details on the net
Old 09-22-2007, 11:49 PM
tower's Avatar
tower tower is offline
Don't know if this will help, but if memory serves, the backspacing is -4.5". You can calculate from there.
Old 09-23-2007, 10:42 PM
5.5"
Old 09-24-2007, 10:56 PM
obzidian's Avatar
obzidian obzidian is offline
obzidian is on a distinguished road
So even if you do the sensor mod, the tires might still damage it if your wheel?
THREAD HIJACK! (Sorry dude! )
I understand that when increasing tire size, you will have changed your gear ratio to a "taller" setup, thus increasing the amount of time it needs to acceterate to the same point as it did with 35's.
But are there any other negative factors that ya'll might want to add? I wheel about 20% and the rest is getting the truck over mall curbs!
Old 09-25-2007, 08:56 PM
Is -6mm offset correct?,
what is size of the rims?
Iv'e gotta get something wider! These are 12.50s.
Anyone else running 13.50 w/air on aftermarket rims?
Old 09-26-2007, 11:34 PM
anyone?
rim size and backspace for air ride w/toyo 37x13.5s?
please!
Old 09-27-2007, 12:37 AM
tower's Avatar
Nice sunroof.
Old 09-27-2007, 12:39 AM
tower's Avatar
anyone?
please!
BradO told you!
Old 10-01-2007, 04:43 PM
BradO told you!
yeah but i'm still confused on the -6mm offset versus -5.5 stock offset.
seems like quite a bit of difference on the offset for a tire that is only 1.5" wider?
