Old 09-15-2007, 04:25 AM
jrs2005's Avatar
jrs2005 jrs2005 is offline
jrs2005 is on a distinguished road
Default 4x2 conversion?
Back in the Day when I owned my first chevy blazer we used to buy a doug nash 4x2 conversion kit and make the normally fulltime 4x4 a 2 wheel drive vehicle when in the normal 4hi position on the transfer case. Helped a lot with gas mileage. Does anyone make a conversion for the H2? Just curious.
Old 09-17-2007, 01:57 AM
dkhummerh2's Avatar
dkhummerh2 dkhummerh2 is offline
dkhummerh2 is on a distinguished road
Default Re: 4x2 conversion?
I don't know, I will keep watching this thread though to see where this goes. What year do you have?
dk
Darin Kaiser
Old 09-17-2007, 05:17 PM
jrs2005's Avatar
2005 suv
Old 09-17-2007, 08:19 PM
johndjmix1's Avatar
johndjmix1 johndjmix1 is offline
johndjmix1 is off the scale
I think this was discussed in the past and, although we all agree it would save a bit of milage, it wouldnt make that much of a difference. The main attributes that give the H2 poor milage is the boxy design, 35 inch tires, high ground clearance, and heavy weight.
Yes, it would make a difference.....but the most difference (At least in my opinion) would be to lower the truck, put some small street-tread tires on it (and change gearing). Would I ever do this? NOPE. But would it get better milage....almost certainly.
I have done a 1 month test, and by just driving slower and gentler you can get 16-17 mpg on the H2......I posted the results of my test a while ago. All it really involves is taking off very slowly, keeping rpms under 2k, and never going over 55mph. But once again, i cant do it now that gas is under $3/gal.
--John
--John
2006 Hummer H2 Lux Series
www.JohnHasMoreFun.com
1/4 Mile 15.29@91.34mph
Mods:
Warn 9.5 Winch
Old 09-17-2007, 09:38 PM
obzidian's Avatar
obzidian obzidian is offline
obzidian is on a distinguished road
this is something i would like to do as well...
I had the number to a company that advertised a HD transfer case that was also selectable.
Old 09-18-2007, 02:53 PM
dkhummerh2's Avatar
I agree! Your gearing hurts the mpg alot. You should consider a programmer. Reasearch one that allows you to change to an economy mode. This would probably help just as much as the transfer case fix, but would cost alot less and you would retain your performance.
thanks
dk
Darin Kaiser
