07-29-2004, 07:48 AM
Does anyone know what is included in this? I'm trying to determine if I can do it myself.
07-29-2004, 10:42 AM
The dealer gave me a chart with the following,...
#1. Change oil & filter,lubricate chassis, check tire pressure, reset service light.
#2. Tire Service, balance 4 tires, set tire pressure.
#3. Transmission Service, Drain & refill transmission, replace filter or clean screens, replace pan gasket.
#4. Radiator Service, Pressure test and check for leaks. Replenish radiator with new coolant.
#5. Differential Service, Service transfer case and front and rear differential.
#6. Brake Service, Clean front and rear rotors & adjust rear brakes.
#7. Brake System Flush, drain, flush and replace brake fluid.
#8. Filter and Accessory Service, Replace fuel filter, PVC valve and service emission system.
#9. Fuel Injection Service, Flush all fuel injectors.
#10. Replace all Spark Plugs.
#11. Battery System Service, Clean Battery cables, service filter system and replace air filter.
Nielsen
07-29-2004, 12:04 PM
2003 Hummer H2 V8-364 6.0L VIN U SFI
Vehicle Level Maintenance Service Intervals Severe Service 60000 MI or 96000 KM
Inspect
Brakes and Traction Control
Evaporative Emissions System (E)
Inspect all the fuel and vapor lines and the hoses for proper hook-up, routing and condition. Ensure that the purge valve works properly, if equipped. Replace the components as needed.
Fluid - Differential
Inspect front/rear axle fluid level and add fluid as needed. Inspect constant velocity joints and axle seals for leaking.
Fluid - Transfer Case
Or every 12 months, check transfer case and add lubricant when necessary. A fluid loss could indicate a problem. Check and have it repaired, if needed. Check vent hose at transfer case for kinks and proper installation. More frequent lubrication may be required on off-road use.
Lubricate
Steering and Suspension
Lubricate the front suspension, ball joints, steering linkage, transmission shift linkage, parking brake cable guides. Ball joints should not be lubricated unless their temperature is -12 degrees C (10 degrees F) or higher or they could be damaged.
Replace
Air Filter Element (E)
Fuel Filter (E)
Oil (E)
Change engine oil and filter as indicated by the GM Oil Life System (or every 12 months, whichever occurs first). Reset the indicator. Never drive the vehicle more than 16 000 km (10,000 miles) without and oil and filter change. The system will not detect dust in the oil. If the vehicle is driven in a dusty area, be sure to change the oil every 5 000 km (3,000 miles) or sooner.
Oil Filter, Engine (E)
Rotate Tires
(S) = Service Warranty Requirement
(E) = Emission Warranty Requirement
(B) = Both Service and Emission Warranty Requirement
Hood Motorsports
- 1967 427 L71 Corvette (99%+ Bloomington Gold Certified, restored to original)
- 1998 Lingenfelter 383 C5 (over 500hp and 11\'s in the 1/4 mile)
- 2001 GMC Yukon Denali (22\" wheels and tires, extensive multimedia system, and per
08-02-2004, 08:51 PM
any clue on pricing.
08-02-2004, 09:04 PM
The book says 1.7 hours of labor time, so take 1.7 and multiply that by the hourly labor rate of your Hummer dealership. Next, add in parts prices (oil, oil filter, air filter, fuel filter, differential fluid, transfer case fluid, and anything else you may need). I would expect it to come out to about $350-$400.
Hood Motorsports
08-03-2004, 07:40 AM
Hummer Village of Norwood Mass quotes it at $600.
08-03-2004, 02:14 PM
Team hummer of pasadena said it would be around $1300
08-04-2004, 01:01 AM
That sounds very high. I just had a 60K mile service on my 2001 Denali and it was around $400. I'll have to dig up the receipt to check, but it also included Mobil 1 synthetic oil and a K&N oil filter.
Hood Motorsports
08-06-2004, 03:20 PM
$400 sounds like a great price.
