Old 09-25-2007, 12:12 AM
dkhummerh2's Avatar
dkhummerh2 dkhummerh2 is offline
dkhummerh2 is on a distinguished road
Default Preventative Maintenence
Just wondering what preventative maint. i should have done on my H2. I get it pretty dirty in the mud etc. What fluids should I change and what intervals. I have 44k miles on it right now. Also what seals etc would need changed with those related fluid changes.
thanks
dk
Darin Kaiser
Old 09-25-2007, 12:23 AM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: Preventative Maintenence
I have found that the 100000 mile Dexcool needs to be changed at 50000 miles if you want to keep your head gaskets .
A government big enough to
you have.
-- Thomas Jefferson
Old 09-25-2007, 12:46 AM
thanks
dk
That info can be found in the owners manual. If you tow a lot, I'd be sure and change the tranny fluid (with that mileage, you should probably change it anyway); if you wheel frequently, be sure and check and change the diff fluid in both differentials. Make sure it's lubed/greased regularly.... If you do a search on here, there is a thread that shows all the grease zerks and where they are located.
