Old 09-25-2007, 11:18 PM
azlifer's Avatar
azlifer azlifer is offline
azlifer is on a distinguished road
Default Am I wrong about this?
My 5 H2 has an air ride system. So it will keep setting the back a predetermined ride height... right? If this is the case then when I rise up the front end Torsion key lift, won?t this also engage the system to compensate for the angle difference? Does this make since to anyone?? And if this is the case then it?s safe to assume that you can adjust the ride height in the back to lower it to level out the front end... right??
Need advice!
