Old 10-02-2007, 03:05 PM
subunix's Avatar
subunix subunix is offline
subunix is on a distinguished road
Default Radar Detector directwire install
Has anyone installed a directwire in the H3 yet? I've got one for an Escort 8500 and was just wondering where people hooked up the wires
"We don't do pretty"
Old 10-03-2007, 12:06 AM
subunix's Avatar
Default Re: Radar Detector directwire install
Went and got a fuse tap , ill let everyone know how it goes tomorrow
Old 10-04-2007, 08:30 PM
aflax24's Avatar
aflax24 aflax24 is offline
aflax24 is on a distinguished road
I have done it, I just pulled the stereo/climate panel and wired it (with a fuse) to the rear wiper switch. I drilled a hole in the small odd shaped dashboard plug located top/center. I also fished wires for the auto mute button to mount it on top of the steering column. Works great.
Took a little time and carved out a block that contours around my detector and stuck it down to the dash. I will post pics.
AFLAX 24Black H3' Adventure Package, Air Raid intake, Wet Okole Seat Covers, 35's, PCM
Old 10-05-2007, 12:18 AM
subunix's Avatar
cool, i just did the wire i didnt do the smartcord, I may get it later on. I ended up piggying off the rear wiper fuse as well, works great
Old 10-05-2007, 12:42 AM
Hucky Hucky is offline
What is a directwire?
Old 10-05-2007, 01:15 AM
subunix's Avatar
A wire you hook directly to your fuse block to power an accessory ie. radar detector, that way you dont have any wires showing and keeps your stuff out of view. Thats the best i can describe it
Old 10-05-2007, 03:04 AM
Got it. Thanks
We always referenced that as a Hardwire or a Direct Connect, Fusable Im with ya now.
Old 05-02-2008, 01:18 PM
DMV631 DMV631 is offline
DMV631 is on a distinguished road
how do you remove the control panel to access the rear wiper wires??
Old 07-30-2008, 12:42 AM
foozed foozed is offline
foozed is on a distinguished road
pics ?
Old 08-02-2008, 02:48 PM
GM_Tech GM_Tech is offline
GM_Tech is on a distinguished road
This info should help You guys.
NOTHING needs to be removed
put Your head underneath the dash by the foot break side to the firewall area. You'll see thick harness. then You'll see smal harness taped to it with blue connector on it. there will be 2 wires in it. Pink and Green. Pink wire is the one You want to use
Old 08-24-2008, 03:55 AM
On a 2008 this harness isnt there - or it is but it has 3 wires..
I didnt have much luck finding a switched 12v on it - but I could have spent more time checking it..
I decided to get a fuse tap with extra power lead from autozone and go that route.
