Old 10-03-2007, 01:24 AM
dna dna is offline
dna is off the scale
Default water is puddling in the driver floor area after 3 straight days of rain
After 3 days straight of rain, I noticed that my drivers carpets are drenched in water - no other area had a problem. I got the shop vac out and sucked it all up (probably the equivalent of 2 to 4 litres of water), but after 30 minutes the carpets were drenched again. I checked the roof liner and all is dry. I could not find any drip from under the console / steering aea. So I removed the side covers and pulled up the carpet and found the source (I think). I have two holes in the floor firewall near the hood release pull arm - two tubes (rubber) run through them which comje from the sterring console. I have no idea where they originate from the steering console - I also do not know where they go under the frame. I think water is leaking from the rim of one of these tubes. Does anyone know what these two tubes are (are they some sort of drain from the roof area)? By hand, I tried to pull the tube out from the hole in the floor firewall, but it is pritty tight.
Anyone else have this problem - what is the quick / easy fix?
