Old 10-08-2007, 12:25 AM
DrG DrG is offline
DrG is off the scale
Default Tie Rod End Grease Seal
After changing my oil, I shot a little grease into the zerts and noticed that I was have a small stream of grease coming out right in the middle of the rubber seal on the passenger side tie rod end. I am not saying it was losing grease at the upper or lower edge as when you overfill it, but this is a tiny hole in the center of the seal. I could reach up there and push on the rubber and more would come out. Is this a leak or is there an overflow valve in these? I didn't see this on the other side and of course, I turned 36000 miles last month too.
2005 H2 Adventure, Nav, Sunroof
