Old 10-17-2007, 03:42 AM
Red face What Parts Needed To Install Factory OEM Air Compressor
I have a lux edition h2 and i would like to install the factory oem air compressor in the original factory location.
i think it goes under the right rear back panel,
after the compressor what other parts would be needed?
has anyone already done this install?
is it a plug and play install or do i need to splice wires?
i see the factory unit has a factory wire harness, is the conector to this harness already there?
any help and advise would be appreciated.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
