Old 10-17-2007, 05:03 AM
twenty2's Avatar
twenty2 twenty2 is offline
Default Anyone know?
What's the name of the web site to get parts for our rigs? Is it gm parts direct? Or, something else.
Old 10-17-2007, 05:15 AM
Hummer Guy's Avatar
Hummer Guy is off the scale
Default Re: Anyone know?
What is it that you're looking for -- you may want to click on some of the "SOMO" banners on this site for accessories.
-Brian
http://www.hummerguy.net
Old 10-17-2007, 05:35 AM
twenty2's Avatar
I need a hub bearing and a ball joint.
Old 10-17-2007, 08:43 PM
Mr. I - Man's Avatar
What the hell did you do? Ball joint only comes as the full upper or lower control arm assembly not a separate part. I had to replace the whole upper control arm because the dust/grease boot ripped on the upper ball joint.
Old 10-17-2007, 10:19 PM
dkhummerh2's Avatar
dkhummerh2 dkhummerh2 is offline
dkhummerh2 is on a distinguished road
I would check ebay for a used upper! Can't hurt to check!
Darin Kaiser
Old 10-17-2007, 10:43 PM
IRA51's Avatar
IRA51 IRA51 is offline
Oh Realy ?
A government big enough to
you have.
-- Thomas Jefferson
Old 10-18-2007, 02:35 AM
twenty2's Avatar
Yes... I actually need the upper control arm also. No idea what happened??? I never go off-road. Then the wheel hub is another question?? I called Naperville Hummer and the parts guy says they are notorious for hub bearings to go bad. That's why every Hummer dealership has them in stock as well as the control arm.
Old 10-18-2007, 06:56 AM
dkhummerh2's Avatar
I had a newer silverado that had the bearing go out, can't just replace the bearing anymore, you have to replace the whole hub!
Darin Kaiser
Old 10-19-2007, 10:48 PM
ratesguy ratesguy is offline
ratesguy is off the scale
I just had to replace my front left hub bearing and pittman arm last week. I got my dealer to match an aftermarket price, but still around 250 for the hub and 200 for the pittman arm. A real biatch to get the pittman off but hub is straightforward. Mine went out from normal wear(now pushing 98,000 miles).See if your dealer will negotiate.
