Old 10-29-2007, 07:17 AM
Red face Front Diff Plug Leak...
I had the front diff oil changed out for royal purple and i now have a small leak from the front diff drain plug,
i notice that this screw plug looks like it has a gasket seal, does this need to be replaced when you change out the diff oil?
the plug is tight so why do i have a leak? should i put some rtv on the plug?
or does it need a new plug screw?
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
Old 10-30-2007, 12:54 AM
Wink Re: Front Diff Plug Leak...
FYI got a new plastic washer #14042602 and replaced the old one. no more leak. the old one looked a bit deformed.
Fabtech Tie Rods
Old 10-30-2007, 12:45 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Default Re: Front Diff Plug Leak...
Plastic washers and metal crush washers should be changed everytime that particular plug is removed. Glad you got it fixed.
Old 10-30-2007, 01:38 PM
jmsspratlin's Avatar
Sounds kinda familiar to what I have going on with mine. I noticed that the front gear box was leaking and I was going through power steering fluid sooner than normal. I managed to get it to the dealer yesterday...guess we'll see what happens. It would be nice if its just a simple fix like this though.
Old 10-30-2007, 08:31 PM
Mr. I - Man's Avatar
I used teflon tape on the thread part of all my diff plugs.
"Healthy as horse not a single drip"
Old 10-30-2007, 08:38 PM
X2
Old 11-01-2007, 08:09 PM
Found out that my truck issue was related to the steering gear. Anyway it was covered under warranty. Also, I had them fix the water leak in the rear window seal. PROCTOR HUMMER is awesome!!!!
