Old 11-14-2007, 06:22 AM
Alan06SUT's Avatar
Default Battery Guru's What is best set up?
Ok, my battery is starting to do funny things. I drove all day today no issues, then I pulled over to get a burrtio and when I came out it wouldn't start. We hooked up some cables to my buddies Explorer and it did nothing. He reved the motor and I hit the key, and it started without hesitation. Then I got home 5 min away, and it started fine again. All this time the radio, lights and everything else worked fine.
Anyway I hope its the battery. I want to go to a dual set up anyway since I have the warn multi mount winch, 12 accessory lights ( I use them very often almost daily), trailer brakes, etc.
I love optimas but according to many sources, they don't have one with the required 880 CCA's??WTF? I saw the yellow top with 900 CCA's but it dosent show as being the right battery for the H2??? And its a deep cycle rather than starting battery.
Should I do this battery X2 or do one red starting battery and one yellow deep cycle battery w/ an isolator? Or use a totally different set up?
TIA.
Old 11-14-2007, 06:39 AM
Alan06SUT's Avatar
Default Re: Battery Guru's What is best set up?
Another question...Does this set up make the CCA's from both batteries available when starting? I.e 800+800=1600CCA's.
Old 11-14-2007, 07:36 AM
tower's Avatar
tower tower is offline
Yes, it makes both available. But they are also both available to drain (neither is isolated for backup). Deep cycle batteries are fine for starting, especially if they meet the CCA requirements. You will do just fine with 1 or 2 yellow tops.
Old 11-14-2007, 01:32 PM
SnakeH2's Avatar
SnakeH2 SnakeH2 is offline
That's purty!
Where's WiFey?
Old 11-14-2007, 02:28 PM
audiofetish's Avatar
TIA.
I have been thinking about running that new 900cc yellow top from optima. The only issue that I have seen is that the posts on the optima are both top post (one is SAE and the other is threaded). I might just change my cables so that I can use it. I have a winch, lights, and a big stereo so I want the deep cycle.
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
Old 11-14-2007, 05:14 PM
Rene S. Nielsen Rene S. Nielsen is offline
Rene S. Nielsen is off the scale
Alan
When your truck didn't start, did you have lights ???
It might very well be your ignition switch starting to bitch.
I had the same issues until suddenly it wouldn't start at all.
Sometimes it would not start, wait 1 day and then nothing. If this is the issue you better get it fixed right away.
If you are stranded turn your ignition on, turn your wheel all the way to the left (i think) then you will be able to reach the starter by going in right behind you right front wheel.
Regards
Rene
Old 11-15-2007, 01:29 AM
Gunzz's Avatar
Gunzz Gunzz is offline
Gunzz is off the scale
Does anyone here know who has this dual battery setup? Battery size? Is the stock battery tray used?
I like this setup except I would want to use an isolator so that I can save one battery for emergency starts. Anybody have info on this pic?
Old 11-15-2007, 04:35 AM
Alan06SUT's Avatar
Isn't there a kit that optima makes for the 900cca battery that "converts" it to side posts?
Old 11-15-2007, 04:36 AM
Alan06SUT's Avatar
I think I found it by using the term "best battery" in the search feature.
Old 11-15-2007, 04:41 AM
Alan06SUT's Avatar
Originally Posted by Rene S. Nielsen
Alan
Regards
Rene
Thanks. I think that may be happening. I have hit the key and nothing happened and then on the second try, no issues??? That was a few months ago. I need to bring it to the dealership one more time before my warranty is up.
Great tip on jumping the solenoid on the starter. I'll use that trick if it strands me again.
Old 11-15-2007, 05:28 AM
gmansbu gmansbu is offline
gmansbu is on a distinguished road
That's my setup/pic. I wish I had answers to all your questions. I picked up the truck a week ago. The preivous owner had installed the dual yellow top setup. I'd be happy to take more detailed pics if it would help in determining what he did. I'll give him a call tomorrow and see if he can give me more information.
Old 11-15-2007, 08:43 AM
Shrek_H2 Shrek_H2 is offline
Shrek_H2 is off the scale
Seems to me like a custom setup i doubt they sell a kit for 2 optima batteries....
Im going with one Optima Yellow top for now and dual alternator setup....maybe a second optima if i can fit it somewhere...
http://www.davesdcelectric.com/pages/5/index.htm
2003 Hummer H2
2000 BMW DINAN 5 (540i)
2002 HarleyDavidson V-Rod "FOR SALE"
All the great toys are on my driveway.....
