Old 11-15-2007, 05:15 PM
BLH2 BLH2 is offline
BLH2 is off the scale
Default REAL WHEELS AIR HORNS
Up for sale is the Real wheels Air horn kit. This kit is awesome and fun. Comes complete with everything needed, Installation is very easy. Was used on wifes H2 for about 1 year. Maybe used 10 times. Only reason for selling is that the H2 was traded in.
Info from Real Wheels website.
With full tank pressure up to 135 psi, this on board air system will not only blow you away with the sound of it's horns, but can also pump up anything else you need. Horn has an exclusive sound chamber, rugged die-cast construction, stainless steel diaphragm, and chrome plating. Doubles as an on board air compressor for external use. Fully assembled for easy installation. Includes everything needed: Dual horns, electric compressor, air tank, hoses, fittings, mounting brackets, extension, and coiled air hose.
All Air Horn components are already attached to the specially designed mounting bracket. Entire unit mounts under the hood with the option of mounting the air horns on the top of the vehicle.
Horn Measurement: 15-1/4"L x 7"W x 3-3/4"H
Decibels: 135db
Model: RW502-1-A0102
Pricing: $549.55 (per unit)
Asking $350.00 with shipping included.
