11-23-2007, 07:03 PM
Picking up a nice used H1 2001 36,000
Hi Guys,
Just thought I would say hi and get you opinions. I'm looking at buying a 2001 H1 with 36,000 miles on her. Any problems I should be aware of on the 2001? I dont think she has even seen a dirt road. Also how do the H1s tow? I'm looking at towing a 7,000 lbs trailer. Thanks for any help.
11-23-2007, 10:09 PM
Re: Picking up a nice used H1 2001 36,000
Sounds like a nice truck from your brief description. I would look for service records, this is the most important factor in buying a nice truck. 2001 was a good year, with all the updates minus lockers. As far as towing goes, they are not tow trucks, a 7K load is not going to be easy on the truck. How far of a distance do you plan to pull the trailer?
1997.5 Black Slantback
The Sole Remaining God Father
-007=
11-24-2007, 06:14 AM
i thought the H1 was able to tow that much? i mean cant the H3 Alpha pull 6000 pounds? and i seriously think the H1 would be easly able to pull more than that.
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
11-24-2007, 06:24 AM
Just because it CAN tow that much, doesn't mean it'd be an easy drive pulling it.
11-24-2007, 05:42 PM
2009 H2 Silver Ice LE
05-19-2008, 09:12 PM
Older H1's can pull 10K depending on hitch setup. The Optimiser and Alpha can pull much more.
I towed wrecked cars with no wheels on the trail, during cleanup with nothing but a tow strap and I didn't feel a thing. The turbodiesel H1's have a lot of torque.
Kurt Williams
1998 H1 HMCO Model 90 6.5L Turbo Diesel
11-24-2007, 06:03 PM
Originally Posted by Sno Ops
Hi Guys,
Keep in mind the 2001 has the following issues.
1- Power Door Lockouts (Fixed in 2003)
2- Exterior Marker lamps are stil recessed into the body (Fixed in 2002)
3- Wheels were 16.5 anf 17" 2 Piece Star Rims. (Later 2002's had the 2 PC Forged Beadlock Runflats Rims)
4- The Lockers are the Same 2001-2002 Detroit Mechanical Locker (2003 Eaton Electronic Loacker Takes Over :-))
5- 2001 have the 8 cyl block crack issue check the vin number to verify if it was part of the build issues 137ZA is bad :-)
6- Make sure the Geared hub seals have been changed if over 20K and the brakes are fresh (Expensive job)
7- Make sure you do not have any HVAC issues with the 2001-2002 they still had issues until 2003 (Updated GM Components in 2003)
8- Lastly where I got burned on my H1 was the pwer steering box. It leaks (by design I think :-0) but only needed a clamp replacment. make sure if it leaks you check the clamp.
Anything else you want to know please feel free to ask. If i was going to get another H1 I would not get anything besides the 03 it was the H1's best year mechanically. Those words are right out of a Hummer H1 builders mouth)
-Peter
CURRENT HUMMER:
Number# 11  2007 H3x Desert Orange
SOLD BUT NOT FORGOTTON
1995 H1 350 HT GAS Black
2001 H1 Open Top Black
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
2008 H2 Black/Sedona
2009 H3T Alpha Solar Flare
11-24-2007, 06:04 PM
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
11-24-2007, 11:18 PM
Thanks for all the info. I am not sure on the Vin number but will check. I would need to tow about 700 miles in on day. So if there not comfortable towing then I will just use it in the Spring and Summer. Thanks.
11-24-2007, 11:23 PM
Heres the Vin: 137ZA843X1E19XXXX. She does have the bad block in her. I think I will hold out for an 2003 H1 instead. Seems like thats the one that I really want anyway with the E lockers! Thanks for your help.
11-25-2007, 02:50 AM
if you pm me the vin I will run a AUTOCHECK for you and send you the results.
-Peter
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
12-07-2007, 01:33 AM
-Peter
Where are you getting all of this info???????
I own a 2001 Open top... I don't believe your post is entirely factual.... never heard of any such power door lock issue,
there isn't anything wrong with the marker lights outboard rather then flush, the LED is nice but both are functional just the same,
2 pc wheels were not offered in 2001, the 17" 2 pc wheels were offered in 2002 for the first time,
the only locker ever offered to a Hummer prior to 2003 was the detroit mechanical locker which I haven't heard of any 2001's having, but the bias ratio in the torsens is different between '01 and '02 but the same '01-'03
the engines in the 2001 are said to be corrected and I haven't heard of any '01s who have had the crack... even with Z engine codes....
mileage is not what intervals seals should be changed at....
the HVAC is the same from 2001-2003 with the only change being the HVAC ducts, the main upgrade was in '97....
please see this link for factual information
to answer the first question.... I tow a 32' travel trailer which, when loaded, weights 10k lbs. Your definatly going to know its back there, but it tows it just fine. I don't travel over 55mph when towing that load though as the temp starts to raise...
12-14-2007, 04:38 AM
An '03 will only get you a rear locker, unless the owner paid to put a front in. '04 is the first year for both front and rear lockers.
05-19-2008, 09:18 PM
If its a high mileage Z block you're likely to be ok. The #8 failure rate is about 25% I heard from an off the record source, most in the first 30,000 miles.
The rest is non issues [Recessed lights? That's an Issue? Really?].
If you want a truck with lockers, get a pre 99 truck that has the engine already replaced and installed whatever locker combination you want. The ABS/TT4 system is garbage.
If you want to get a nicer rig out of the box, get an used 04, those are the best rigs unless you want a to drop 100-115K for a used Alpha.
Most of the enhancements on the H1 in regards to HVAC and drive train tweaks was rolled in halfway through the 1997 production run. So anything 1997.5 or higher with a service history and a replaced engine would be ideal.
Kurt Williams
05-19-2008, 10:43 PM
If you are interested check out my 02 I am looking to sell on the post 2002 thinking of selling.
Bryan
05-20-2008, 02:43 AM
Just because you have a "Z" engine, it doesn't mean it wasn't replaced. Call Lynch HUMMER. They can tell you if the engine was possibly replaced.
98 TD HMC4
05-20-2008, 06:09 AM
Don't get afraid of a 2001 model year, most all of the issues were worked out in the mid 90's. A 2001 is nearly identical to a 2003 for a good bit less $$$. Lockers cost $1500 installed each ( if you really want them). Many say the best year for offroading is the 1997.5 it has no TT4, 6.5TD, updated air, Torsen I diffs that are easier to BTM than the Torsen II that came with the TT4 trucks. But, after wheeling with all years, they all are simply amazing and very similar in capability regardless of if it came with lockers, torsen II, etc. I like the 99-01 years right now because you can find one for a steal and I bet they have hit bottom as far as depreciation.
Hybrid Mode
