Old 11-27-2007, 10:58 PM
dkhummerh2's Avatar
dkhummerh2 dkhummerh2 is offline
dkhummerh2 is on a distinguished road
Default abs light and tracton control light
My abs light and traction control light came on yesterday while I was setting there ideling and now it is on all the time. If just snowed here so I didn't know if something was messing with it or if something is wrong. My buddy has a shop and can check the computer but that won't be until this weekend. Just wondering if anyone else has had a similar issue.
thanks
dk
Darin Kaiser
Old 11-28-2007, 12:57 AM
mikejr's Avatar
mikejr mikejr is offline
Default Re: abs light and tracton control light
Check with Humtech he knows his way around the Hummer big time.
2009 H2 Silver Ice LE
Old 11-28-2007, 01:07 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
You can check wheel speed sensors for any moisture in them which can cause issues. Other than that I would pretty much need a code to point you in the right direction.
Old 11-28-2007, 02:10 AM
lonePalm's Avatar
lonePalm lonePalm is offline
lonePalm is on a distinguished road
I have all kind of issues like that, it happens every now and then but mine started after I installed the ultimate ipod adapter(nucleus) just my 2 cents!
Drive fast and Beep the horn!
Old 11-28-2007, 05:06 PM
dkhummerh2's Avatar
My buddy will bring up the code this weekend. I thought bout disconnecting the battery and letting everything reset. Do you think this would work. I just don['t want to do it if not, because I will lose all of the data in my head unit
thanks
dk
Darin Kaiser
Old 11-28-2007, 11:02 PM
dkhummerh2's Avatar
Another question. I replaced the power steering pump last month. It kindof sounds like its whining more than usual. If i got a bum pump, could this do that>
thanks
dk
Darin Kaiser
Old 11-29-2007, 02:25 AM
HUMTECH's Avatar
The pump should not cause any issues, the brake system just uses the power steering pump for brake assist. Better off not disconnecting the battery if you can get someone to read the codes for you. If the fault is not current the code wont reset and you will have to wait till it fails again to retrieve a code. Better off finding the fault and fixing it in my opinion. Some people dont feel this way, hell I have cleared codes out of my truck just cause I didnt want to fix it but i have my own scan tool for my laptop that i take with me on any roadtrip and can usually take care of any problems on the road as long as i have the parts or access to them.
Old 11-29-2007, 04:18 AM
tower's Avatar
tower tower is offline
thanks
dk
If you have Stock head unit, only loss will be clock time.
Old 11-29-2007, 04:44 AM
HUMTECH's Avatar
I thought stock head unit meant wife
Old 11-29-2007, 04:57 AM
dkhummerh2's Avatar
Mine is aftermarket.
Darin Kaiser
Old 11-30-2007, 01:00 PM
dkhummerh2's Avatar
the snap on computer can't bring up a code. any ideas?
Darin Kaiser
Old 11-30-2007, 08:17 PM
HUMTECH's Avatar
You need to find a scan tool that can read chassis codes, any scanner that has gm enhanced capabilities in it. Or go talk real nice to a local gm tech and maybe he may scan it for you. I have done this for customers before.
Old 01-28-2009, 03:33 AM
twenty2's Avatar
twenty2 twenty2 is offline
Mine just started doing this the other day... When I turn the engine off, and restart... then they go away.. What was ever the outcome of this???
Old 01-29-2009, 12:58 AM
splne1's Avatar
splne1 splne1 is offline
I just changed the abs sensor and worked like a charm!!
Old 01-29-2009, 06:02 PM
twenty2's Avatar
dumb question...... but, is it easy to change?
Old 01-29-2009, 06:09 PM
twenty2's Avatar
Would you happen to know the part # to it? Napa has no listing for a ABS Sensor? How much was it?
Old 01-29-2009, 06:20 PM
splne1's Avatar
I bought mine of ebay and came with 2 they were used but I will send you the other one PM me your addy
Old 01-29-2009, 08:39 PM
twenty2's Avatar
pm you..
Old 01-29-2009, 08:44 PM
twenty2's Avatar
how'd you figure out which one was bad? Sorry for all the questions
Old 01-31-2009, 04:20 AM
splne1's Avatar
Had the wife sit in the truck while i messed with the sensor wiring to each hub then when I found the culprit on the passenger side i removed the tire and discovered it had a severe gash. Then just remove the caliper, brakes, and disk and use an allen wrench to remove old sensor. Plug in new one and verify light goes out!!! Re-install and enjoy!!
