Old 11-29-2007, 12:58 AM
breezss breezss is offline
breezss is on a distinguished road
Default Extra accessory....??
I was wondering if anyone has installed (of if it can be done) an extra accessory output? With the cell phone and the GPS on the far right of the windshield..it would sure be nice to have a plug in right there on the far right of the dash so the wires are not run all over the dash. Between the GPS, XM. and the Cell I am short one if something happens and they all need to be charged anyway.
Thoughts on this??
Thankx everyone.
Breezss
Old 11-29-2007, 05:42 AM
tower's Avatar
tower tower is offline
Default Re: Extra accessory....??
Thoughts on this??
Thankx everyone.
Breezss
Yes. If you don't smoke or can part with having the cigarette lighter handy, you can use that as a power outlet. Also you can use an add-a-circuit or a tap a circuit in your fuse box and then easily run a wire behind the dash to the passenger side where you can install another outlet in the dash or glove box. Either way, be certain that you get the ATM type, NOT the ATO type. These are available at most auto parts stores.
://www.radarbusters.com/radar-detector-accessories/other-accessories/radar-detector-accessories/other-accessories/addacircuit.cfm?source=gbase&tid=RAD003&gbid=Add_A _Circuit#details
http://www.littelfuse.com/data/en/Data_Sheets/FHM02FHA02.pdf
http://www.wirthco.com/tapa_circuit_...lder-p-99.html
If all else fails, you can order one here:
http://www.jcwhitney.com/autoparts/I...D:100000205668
Old 11-29-2007, 06:01 AM
You all are the best! Thank you!!
Old 11-29-2007, 06:39 AM
tower's Avatar
You're welcome. Glad it helped!
