Old 12-03-2007, 10:22 PM
tower's Avatar
tower tower is offline
Default I need sunroof help!
My sunroof will start to close but get hung up. When there is enough resistance it will stop. It opens without any issue. I can close it by assisting with my hand (pushing it shut). Does it just need lubrication (and if so, where and with what?) or is a dealer visit in my future?
Old 12-03-2007, 10:53 PM
Ed G.'s Avatar
Ed G. Ed G. is offline
Ed G. is off the scale
Default Re: I need sunroof help!
Had the exact same thing happen to my '03 about 6 months ago, had to take it to the dealer. They took down the headliner, took out the glass, greased & adjusted the frame. No problems since!
2008 H3 Alpha - Boulder Gray
Old 12-04-2007, 12:58 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
I have seen many where the guides are broken and cannot be purchased separtly from the entire sunroof assembly less glass. If the guides break the glass does not track straight and will reverse or just stop. You can tell by watching closely when it is closing and if the glass cocks sideways you can bet the guides are broken. I have seen no other fix other than replacing the entire module. Not what you wanted to hear i know.
Old 12-04-2007, 02:34 AM
I agree. I've been dealing with it for almost a year now. In order to close the sunroof, I have to push the button with one hand and push UP with the other.
Don't push forward, push UP... it keeps the tracks straight. I started pulling it apart to see what the problem is and it's just a crappy design.
I even paid an extra 300 dollars on an extended warranty to cover the sunroof when I bought it.
When I made the claim to fix it, they refunded my 300 bucks and told me to pound salt. I couldn't do anything about it because they found out I put a supercharger on it and said they would drop me if I pursued it.
Oh well, guess I'll continue pushing upwards for a while. I ain't spending 1600 bucks for a new setup. (though I saw one go on ebay for 400 bucks....missed that one)
Mark
Old 12-04-2007, 06:44 AM
tower's Avatar
Thank you all for your replies. It looks as though I have a trip so the dealer in my future. No biggie. I have the extended. They won't void my warranty for having a chip will they? Should I not tempt fate and just remove it before I go in?
Old 12-04-2007, 02:11 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Yes, definitely remove it before you take it in. Take no chances.
Old 12-05-2007, 02:45 PM
TXSUT's Avatar
Originally Posted by hummech
the way extended warrantys work is if you modified the vehicle and that modification causes the failure to the part it would not be covered just like the factory warranty.
That's if, and only if, you have a reputable and upstanding dealership...and how many of those are there?
Old 12-05-2007, 05:58 PM
tower's Avatar
I definitely trust Tustin Hummer! (Used to trust Cerritos.)
Old 12-21-2007, 12:00 AM
aiden416 aiden416 is offline
aiden416 is on a distinguished road
Forget the dealers. Go to an aftermarket warranty company. I did, they take good care of me.
There is no reason why they should charge $300.00 to cover the sunroof. That is included in my coverage.
I agree that any modifications will void ANY warranty. They make that clear before you purchase, if you ask.
Anyway the place where I got my warranty was the only one I found that offered coverage on my H1. For those of you who are interested here is the link.
http://www.warranties4wheels.com
Old 12-21-2007, 08:16 AM
HUMTECH's Avatar
Warranty is warranty, if it falls under factory warranty an aftermarket warranty company will not cover it. Sorry just dont see your point here. After factory warranty expires then your aftermarket policy goes into effect.
