Old 12-05-2007, 06:05 PM
twenty2's Avatar
twenty2 twenty2 is offline
Default New Hub/Bearing
Just wondering if any of you have had to change your hub at all? And, knowing that I have to change 1, should I just do both????
Old 12-06-2007, 12:41 AM
orlasttoy's Avatar
orlasttoy orlasttoy is offline
orlasttoy is off the scale
Default Re: New Hub/Bearing
just had mine changed on an '03 w/ 61k miles...
thats all i know...100% trust in my dealership HAAAAAA
Old 12-06-2007, 12:51 AM
H2 Bill H2 Bill is offline
What kind of symptoms did you have?
1994 Chev Suburban Blown
Old 12-08-2007, 01:29 AM
1GaNole's Avatar
1GaNole 1GaNole is offline
1GaNole is on a distinguished road
I had to replace my front right hub in June, '04 with 80k miles. $350 plus labor.
Old 12-08-2007, 03:11 AM
Yetti Yetti is offline
if you suspect a bad hub or bearing do a couple of quick tests while driving. you will need a road with a long curve like an exit ramp. if you hear a howl or hum from the suspect bearing put it into the a curve to transfer weight away from the bearing. if the noise quits its most likely the bearing on the inside of the turn. I have also found if you back up at low speed with the wheels cut hard one way or the other you can find bad CV joints, listen for the then to "Clunk" repetedly while turning.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 12-18-2007, 07:21 PM
dochummer's Avatar
I have that problem with turning right on off-ramps. My right WB is bad. I found them on ebay for $140. Just haven't bought one yet. Shouldn't be too bad to replace it yourself...
'03 H2
Old 06-10-2010, 01:12 AM
Braveheart7's Avatar
Braveheart7 Braveheart7 is offline
Braveheart7 is off the scale
I have an increasing noise... sounds like a WW2 Bomber wwoooooooowoooooooowwooooooowooooooo starts at 36 Mph and just gets louder.
seems to be drivers side...swapped tires ( looking a little worn) front to rear... noise still there.
drive up the road and rock steering to left ( truck then tilts onto the passenger side) noise goes away........ truck levels out..... My bomber is back again.
bought a bearing (complete HUB with ABS sensor $85) and got my tech guy to stick it on.... FRICKIN NOISE STILL THERE .
Get up to speed and knock it into neutral ..... noise there.... is there a inner bearing???? I can see a flange at the end of hte drive shaft
Or are we then talking diff bearing..
anyone else having this challenge... noise is insane..... actually wish the bearing would blow out so I knw for sure which one it is.
Old 06-10-2010, 01:23 AM
BTW here is the link I got th ecomplete HUB with Bearing and ABS sensor for $ 80
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160433023771&viewitem= &sspagename=STRK%3AMEWNX%3AIT
Old 06-10-2010, 01:47 PM
FiremanJay's Avatar
FiremanJay FiremanJay is offline
FiremanJay is an unknown quantity at this point
I have had to replace the Hubs on both of my side once already, currentl waiting for the timkin ones to come in for the 2nd time to replace.
my '03 has 150K on her.
here is a great link with step by step instructions and pics
http://www.mcratracing.com/wheel_bearing.html
i used this the first time i replaced them took me about 4 hours to do both sides, will probably take me a little less time this go around.
I id have to get some replacement nuckle bolts due to the fact thaty a couple of them were rounded off, so i will see how my bolt extracter set works.
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
