Old 05-09-2003, 12:12 AM
dm dm is offline
dm is off the scale
It seems my electronic brake controller I had installed for my Airstream trailer is disabling my cruise control. the Hummer dealer confirmed that as song as it is engaged it is disengaged by the controller. My trailer dealer is a bit stumped as to why this is happening. Anyone have any ideas ?
dm dm is offline
dm is off the scale
Old 05-09-2003, 11:51 AM
DURAMAX TIM is off the scale
I haven't put the Suburban controller in the H2 yet (need more miles before towing) I have them in other new GM trucks (should be same system) and it works fine.
I'm running Kelsey controllers.
If I have some time in near future I will put it in and try out one of the trailers.
Did u get factory plug to hook it up?
If they spliced wires they could have done something to brake lite switch.
Did they check the brake lite switch to make sure it is working OK?
If u have factory plug unplug it and see if it is OK then.
When I questioned the Hummer dealer anbout the trailer brakes I got that blank look so I looked under dash myself and pulled the cover off to check it and found it is same as all other GM vehicles.
U might call a GM truck dealer and see what service has to say about the problem (they should have FAR more experience w/ trailers).
98 ZR-2 Blazer
Ex H2&3 owner
Old 07-18-2004, 07:19 PM
GasGuzzler's Avatar
GasGuzzler GasGuzzler is offline
GasGuzzler is off the scale
I have an answer to this old question.
For the cruise control to work, you will have to add a load resistor across the 2 wires(positive and negative) connected to the brake controller.
Check Ebay for the load resistors
03 Yellow Hummer H2 - Wife's School Bus- Pioneer AVIC D3 w/ backup camera/iPod integration/Sirius, 24" DropStars with 36" Pirelli Scorpions, Real HIDs, Bling-ed out...
04 Black Acura TL full A-Spec
88 Red Porsche rare 930 Cab
Old 07-18-2004, 08:44 PM
You don't need load resistors to correct the electric brakes issue. Most dealers should know how to remedy this. If not, this from a post over a year ago<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Redrum:
Your trailer brake controller requires 4 wires to work properly
1) + Positive lead
2) – Negative ground
3) Brake light switch
4) Brake controller lead to rear hitch
GM neglected to terminate the brake light switch and brake controller lead in the convenience center. You have a couple options.
Option One:
Locate the brake light switch and brake controller lead (blue and red) wires that are located underneath the fuse box in the engine compartment. You will have to remove the fuse box to get to them. There are four bolts holding the fuse box down.
The easiest way to get them hooked up is to bring them through the firewall to the convenience center or directly to your tekonsha wires.
If you have the grille mounted spotlights, GM plugged their terminating connector into the trailer brake controller location (Top – second from the left) in the convenience center.
You can share that connection for the trailer brake controller and spotlights, by splicing the wires into the spotlight wires but I do not recommend it. Since the only reason you need to use that cavity is because you need (+) and (-), I suggest you pull a (+) and (-) from the engine compartment while you are pulling the brake light switch and brake controller lead. . This way you can use the spotlights and brake controller without sharing the same plug. You can also Find a (+) and (-) on one of the other spare cavities on the convenience center. Just use a 12 volt tester. They are there.
Option Two:
If you don’t want to pull wires from the firewall you can
A) BRAKE LIGHT SWITCH: Connect a wire from your tekonsha to the fuse box located on the left side of the dash near the drivers side door. You will find the “brake light switch” fuse in that fuse box.
B) BRAKE CONTROLLER LEAD: Pull a wire from your tekonsha directly back to the trailer hitch plug and terminate it at the plug.
C) Find a (+) and (-) on one of the other spare cavities on the convenience center. <HR></BLOCKQUOTE>
