Old 12-09-2007, 03:30 AM
RippSpeed RippSpeed is offline
RippSpeed is on a distinguished road
Default Tire sizing question...
I'm ordering a set of 20"s but I was thinking of running 325/50-20 Mickey Thompson BAJA ATZ ... I rulled out the Kumho because I dont want too much tire size wall... 35" tires is the biggest I want to go ...
Old 12-09-2007, 02:28 PM
Yetti Yetti is offline
Default Re: Tire sizing question...
you will be fine, the stock tire are right around 34" high so you shouldn't have clearence issues unless you go more then about 12.5" wide, then they may rub going up driveway approns and such. I'm sure the other guys on here have done simular swaps. try doing a search on "tire size" you will find a bunch of stuff.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 12-09-2007, 05:05 PM
Baja ATZ Specialty Radial, LT325/50R20
  • Black Letters
  • Load Range = E
  • Max Load = 3085
  • Tread Depth = 19/32
  • Overall Diameter = 29.3
Unless you want a 30" tire on teh H2, you may want to do more research.
This took all of 5 minutes to search.
http://www.mickeythompsontires.com/t...=BajaATZRadial
order the 35 1250 20's.
Old 12-09-2007, 10:10 PM
tower's Avatar
tower tower is offline
That's correct. The calculated tire size would theoretically be:
32.8" x 12.8",
but the manufacturer knows the idiosyncrasies of their tires. Either way, that's a totally weenie cholo looking size.
