Old 12-16-2007, 04:54 PM
WHOSNEXT's Avatar
WHOSNEXT WHOSNEXT is offline
Default backup lights....for trailer hitch?
does anyone know who sells them for a h2? i know i have seen them on fords and chevys but have not seen them on a h2, its lika a insert that goes around hitch with 2 oval lights, one on each side. thanks for any help
Old 12-16-2007, 05:48 PM
mikejr's Avatar
mikejr mikejr is offline
Default Re: backup lights....for trailer hitch?
http://www.premiermotoring.net/cgi-b...l?p_catid=1459
not sure if they work on the H2 or not, but its a place to start.
2009 H2 Silver Ice LE
Old 12-16-2007, 06:04 PM
WHOSNEXT's Avatar
that is it...thanks .....does not show for h2....has anyone tryed this?
Old 12-16-2007, 06:22 PM
mikejr's Avatar
reach out to those folks maybe they can point you in the right direction.
I know the stock back up lights just dont give off enough light nor do they direct it in the right area. It helps having the back up camera thats for sure.
I've also seen back up lights that fit in the electrical socket for the trailer plug, i think they are similar in that they are a 55 watt halogen also. But with the configuration of the H2, that would likely just direct the light downward.
Old 12-18-2007, 03:58 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
You could also try replacing your bulbs in your existing back up lights..... not sure where but I have seen these before and they make quite a difference.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 12-18-2007, 07:00 PM
WHOSNEXT's Avatar
thanks guys....i just order 1 of these....ill let you know how it works.
