Old 12-17-2007, 09:08 PM
iccon's Avatar
iccon iccon is offline
iccon is on a distinguished road
Default remove from drive shaft
I want to remove my front drive shaft for the summer months to save gas any one see any problems that might arise
Old 12-17-2007, 10:25 PM
MDimitri's Avatar
MDimitri MDimitri is offline
Default Re: remove from drive shaft
You should try doing a search, your question has been asked a few times in the past, here is a link to one of the posts that will relate to your question: Drive Shaft
Good Luck!
Old 12-18-2007, 03:50 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
More trouble than its worth, removing the shaft is more complicated than just removing bolts since I believe the rear end of the shaft is a splined yoke that slides onto the transfer case spline (similar to how a torque converter sits on a transmission).... removing this will result in fluid loss. I also think any mileage gain (should you figure out a way) would be minimal at very best.... like maybe 1mpg. If your looking to save on mileage get yourself a tune, air intake and switch all fluids to a synthetic such as royal purple, with all this you may see a 2MPG increase if your lucky
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
