12-02-2005, 01:50 AM
Will and 05 H2 IPC work in an 03 H2? The guages look diffferent but will the connection match up?
Jeff / aka: Jethro / aka: Redneck
H1 - 95 NA (My HMCS)
H2 - 03 (Wife\'s)
Freedom does not come free...
Thanks to all that have served and to those who are actively protecting the freedom that we take for granted!
H2 - 03 (Wife\'s)
12-02-2005, 02:00 AM
OK, I have answered my own question. The 03 through 05 are all interchangable.
Now the question is... If I can get one for under $300 is that a good deal?
H2 - 03 (Wife\'s)
12-02-2005, 02:29 AM
Actually, you should be able to get one for even less than that. Don't forget to put the nifty little sticker on your door to let everyone know that the odo is not original miles as that info is stored in the IPC.
12-02-2005, 03:02 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by kodiakz:
Actually, you should be able to get one for even less than that. Don't forget to put the nifty little sticker on your door to let everyone know that the odo is not original miles as that info is stored in the IPC.  </div></BLOCKQUOTE>It seems as though that you can take it to the dealer and they can update the mileage on the ODO using a Tech II. Mileage is stored in 1 or 2 other components, seems like.
I think it reads it from the BCM
12-02-2005, 03:16 AM
Anyone have a souce for H2 parts other than the dealer? I know where to H1 parts but not H2.
H2 - 03 (Wife\'s)
12-02-2005, 02:50 PM
The IPC is programmed at the Delco electronics repair center.
Milage is stored in the IPC.
12-02-2005, 02:55 PM
M101A2 Trailer
12-03-2005, 01:22 AM
Should be around $295 range. Mileage cannnot be updated via Tech II, partsguy is correct in that only the specefied Delco (or is it Delphi now?) can do any programming to them. If you were to change out yours with a new one, the tech II (according to everything I have been told) would only read the mileage stored in the new unit--not the old mileage from perhaps the pcm or abs unit as I had once thought.
