12-29-2007, 07:22 PM
Who here is good at Wok cooking?
I just got a new Wok for Christmas and need some input of things I need and need to do so as not to ruin it or destroy my first attempt at cooking in it.
12-29-2007, 07:49 PM
Re: Who here is good at Wok cooking?
My wife's good at cooking in a Wok ! I'm great eatin' it ! I'll ask her some advice !
12-29-2007, 09:01 PM
Great book, "50 Ways to Wok your Dog"
12-29-2007, 11:30 PM
tell right after my afternoon wok.....
12-29-2007, 11:39 PM
well I figured out a little. do not use frozen green beans...thaw them first. and oh my does it cook chicken fast. I did the slice and dice on 2 lbs of chicken breast and it cooked in about 5-7 miinutes, way better then my Echo pan... I'll save it for burgers.
12-30-2007, 12:07 AM
CO is the master of wok cooking. He's got his own restaurant.
12-30-2007, 03:28 AM
is it steel , alum or cast iron ???
is it for use on a gas stove or is it electric ???
how big is it ???
is it using a non-stick surface ???
12-30-2007, 04:03 AM
well after reading a bit about them on the web I found I have a steel teflon coated one. my biggest concern is how to tell when its at the proper heat. the info I see the most about cooking with one is to watch for smoke when it reachs its optimum heat. I have an electric stove so its easy to set the heat, but I have to learn where it needs to be to get the right cooking heat without seeing smoke.
12-30-2007, 06:05 PM
if the food does not cook, not enough heat....if the pan melts or warps, too much heat...hope this helps......
12-30-2007, 09:39 PM
I gotta tell you from my 42 years of cooking, eating, teaching cooking, chefing, BSing and other things...
its dam hard to cook with a WOK on an electric cook top...almost impossible
sorry...
12-30-2007, 10:14 PM
I have to agree, gas is the way to go when using a wok.
12-31-2007, 12:25 AM
well I did ok for the little I used it yesterday. even on an electric stove its a huge difference in fry cooking. the fact it has a flat bottom makes the diff as compaired with a standard wok. if it didn't touch the burner then yes it would be very hard to work with.
Hybrid Mode
