Old 01-06-2008, 08:04 PM
Default Laptop battery question
So, I replaced the original one and it does last much longer but now I get no warning about low power. It just locks up. It is defintely at the end of its cycle because it doesnt even really have enough power to boot up, run a disk scan and log on but I would really like to have a warning before it locks up.
Old 01-06-2008, 08:12 PM
Default Re: Laptop battery question
Disc scan wont help. Try cycling the battery by putting it in. Running it down and then charging and run it down again...
By exercising the negative to the positive elements. The battery becomes stronger and learns to last
Old 01-06-2008, 08:35 PM
That will only work on Ni-Cads that are not to far gone...
don't do chit on Lithion-ion or the newer one(can't remember name)
Old 01-06-2008, 09:00 PM
mikejr's Avatar
mikejr mikejr is offline
i learned my lesson....running a dell xps m1710, battery went out in 12 months. I was always on the charger either at home or the office...so now with the new battery, i run up the charge then let it go down to low batt warning. Hope this lets me get more than a year out of the battery!
2009 H2 Silver Ice LE
Old 01-06-2008, 10:06 PM
RYD,
Surprised you remember many things however principals of electronics do not change much with practices of battery. Since Edison charging of batteries have not deviated.
Old 01-07-2008, 12:09 AM
Big Dad's Avatar
Big Dad Big Dad is offline
RYD,
So in essence, what you're saying is the Nickel Cadmium battery has/was never known for building up a "charging" Memory? You know, often resulting in a lower state of charge, rather than full charge.
I'm not getting the RYD's back on this one, however....
Old 01-07-2008, 01:25 AM
Adams question does not pose type of battery in question. My proposition is there is nothing new under the sun!
