Old 01-09-2008, 12:49 AM
avking avking is offline
avking is on a distinguished road
Default Heater Issue
I just picked up a '95 H1 Wagon (Diesel) and have HVAC issues. I knew about them when I purchased it, so it is no big deal. I have the original HVAC system with the digital control panel. I know these systems are terrible and that the $4500 conversion is what most will tell me to do. I will be doing that, but I want to try and fix what I have in the meantime.
The blower works fine and at all the speeds it should blow at. The problem is that the air temp is the same no matter what I set it to. I know the A/C has a leak and is probalby empty and that would keep me from getting any cold air. But even after three hours of driving, the air does not heat up when set to the highest heat setting.
Can I get some pointers on what to look at to get the heat working? I really need the defroster to work at least a little, this time of year.
I ordered the service manuals, but will not have them for at least a week and want to try and work on the issue this weekend.
Thanks in advance. (I am located in Santa Barbara, CA).
