01-15-2008, 04:43 AM
FABTECH Lift ?
I'm going to be getting the 6" Fabtech lift. I've got a 2006 with air ride, does anybody know if I will have problem with the rear air sensor?
Also what is the best backspacing if I run 40" tires?
01-15-2008, 02:18 PM
Re: FABTECH Lift ?
i had a fabtech 6 inch lift with air ride on a 04 .. i had no problems.. but i seem to remmeber something about 06 and up sensors not being adjustable. but im sure their is a way to do it.
01-15-2008, 11:43 PM
Re: FABTECH Lift ?
Ya I can't seem to find a solid anwser if this lift will work on a 2006 with air ride! I have my heart set on this lift but if it doesn't work what would your guys second pic be?
01-16-2008, 09:53 PM
Re: FABTECH Lift ?
there is 2 diffrent kits, one for spring and one for air.
make sure you order the right one.
01-16-2008, 10:37 PM
Re: FABTECH Lift ?
What does Fabtech say?
01-17-2008, 02:03 AM
Re: FABTECH Lift ?
On Fabtech's site it says that it should work on a 2006 with air. On Trailduty.com it says Air Suspension - 03-05 Only but they probably havn't updated there site.
01-17-2008, 03:09 AM
Re: FABTECH Lift ?
I don't know about you but when I shell out that much dough  the words "should fit" are not in the equation. I would call Fabtech and see if they can give you a straight yes or no.
01-17-2008, 04:21 PM
Re: FABTECH Lift ?
as i said there are 2 part numbers, it dosent take but a sec to check.. from fabtech site
01-18-2008, 01:31 AM
Re: FABTECH Lift ?
I have been in contact with Fabtech via email and they have told me that their 6" lift will NOT work with my 2006 air ride SUT. The rear suspension on a air 06 SUT is different then past years so they are working on a fix right now.
01-22-2008, 12:12 PM
Re: FABTECH Lift ?
Is ditching the air ride an option? You could just put the coil springs that come with the Fabtech kit on the truck. I'm not sure if this has been done before or not?
01-22-2008, 05:32 PM
Re: FABTECH Lift ?
THey've been working on that "fix" for a while now. It's due to the non-adjustable air ride sensors.
01-23-2008, 04:59 AM
Re: FABTECH Lift ?
Mine worked fine. Had a different mounting bracket for the sensors that were slotted.
MINE - 2006 H2 SUT
