Old 01-27-2008, 12:50 AM
Default HID DRL'S???
Wondering how to get my drl to match my heads(9007's) so im lookin for hid 3157 somehow in hid nyone seen em??? not just the white bulbs either is there anyway to run real hid in drl slot???? THANKS
Old 02-10-2008, 05:48 AM
Don Flaminco's Avatar
Don Flaminco Don Flaminco is offline
Don Flaminco is on a distinguished road
Default Re: HID DRL'S???
If you type in 3157 led on ebay you will find a 3157 bulb that is led and they look really bright
Old 02-10-2008, 03:35 PM
LEcustoms's Avatar
LEcustoms LEcustoms is offline
LEcustoms is off the scale
I believe the navigator fog lights fit in the DRl spot. If you get a set of those then you can do a HID swap since they are actual fog lights designed for a higher wattage bulb. Chances are you won't find a HID bulb for a 3157. I sell HID and have never before seen a 3157 bulb. If you really want to use the OEM DRL's you can probably order a like a 9005 HID kit and just silicone the bulb in the housing but your really not going to get much focused light out of those housing because it's reflector is not designed for road illumination. I tried it on my truck and i was lighting up the trees. I'm not saying it won't put out light, just not a very focused light.
"A clear conscience is usually the sign of a bad memory."
03 White H2
12 HID lights, factory lightbar, custom light bar for brush guard, OEM luggage rack, k&n intake, Gran MAF, 37" Toyo M/T's, 17x12 weld racing wheels, predator programer, Dynomax 4" catback exhaust,
02 10th Anniversary H1 #44 Will be missed
94 Custom pearl white H1(work in progress)
Too many mods to list
06 kawasaki stx-15f
02 yamaha superjet
02 polaris scrambler 500
