Old 01-28-2008, 07:39 PM
nicos nicos is offline
nicos is on a distinguished road
Default solution to hard ride after leveling
i have an idea which i want to discuss with you.
IFS works as levers(A arms)acting on the torsion bars.when we level our trucks we move the levers downwards to gain lift.this reduces the leverage efficiency on the torsion bars thus giving us a harsh ride on the small stuff(upto the point were the A arms return to there initial position ie before leveling)
my question is this,do you think that if we can somehow measure the difference in leverage length before and after leveling of the A arms,and add spacers or different offset rims to our H3's (or any other IFS truck)we can fix this problem?
just thinking out loud !
Old 01-29-2008, 12:26 AM
Default Re: solution to hard ride after leveling
You're also increasing the pre-load on the torsion bars and the shock is no longer operating in its normal range of motion.
Get the Cognito/Bilstein shocks and the SAW or Alpha torsion bars. Problem solved.
Old 01-29-2008, 05:57 AM
tomp's Avatar
tomp tomp is offline
Its nothing to do with leverage my friend. You shocks are limited in downward "droop" when you crank up the TBs. Just install the longer Cognito/Bilstein shocks and you will be back to normal
Old 01-29-2008, 07:36 AM
i already have the cognitos!
would other torsion bars really give me that factory ride again?if so i want to order asap!
pls let me know which ones to get since our roads over here are not too good and i'm beginning to feel that my H3 is shaking itself to bits!
thanks for your replies!
Old 01-29-2008, 04:21 PM
tomp's Avatar
There is virutally no increased stiffness due to leverage effect of raising the front end. The H3 rides somewhat stiff from the factory.
If you want it to ride more plush, you need to drop it back down & add the Rancho 9000 shocks
Old 01-31-2008, 02:22 AM
Kaiser Souza's Avatar
Kaiser Souza Kaiser Souza is offline
Kaiser Souza is on a distinguished road
That is not true buddy, mine is stiffer ride and virtually rock solid to push down by hand, I pushed one at the dealer theother day and it flexed down easily.
"I didn't mean to wreck him, I just wanted to rattle his cage." D.E. 1951-2001
