Old 02-05-2008, 03:35 AM
Major Tom's Avatar
Major Tom Major Tom is offline
Major Tom is on a distinguished road
Cool cb coax
I am going to put a CB antenna on the rear of my truck.how have people run the coax from the back to the front.Do you need to remove a lot of body panels or kick plates.
Old 02-06-2008, 02:22 AM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
Default Re: cb coax
its not too bad. I ran mine from the rear bumper, through the taillight housing and into the rear of the truck. then I tucked it under the side trim on the inside and up to the drivers center console via under the sill plates.
____________________________
Old 02-08-2008, 01:03 AM
Major Tom's Avatar
Default Re: cb coax
Thanks. It doesn't sound too bad.I may give it a try this weekend.
Old 02-09-2008, 12:02 AM
SR1355's Avatar
SR1355 SR1355 is offline
Default Re: cb coax
You can also run it under the roof rail covers. Take a pillar cover off at front and rear a-pillar cover off and you can pull wire thru with electrical "fish" tape.
Paul M
SR1355
Old 02-09-2008, 06:14 AM
Major Tom's Avatar
Post Re: cb coax
How do the A pillar covers come off,screws,plastic snaps.Every time I mess with plastic snaps I break them.
Major Tom
Old 02-14-2008, 02:01 AM
Crash ?'s Avatar
Crash ? Crash ? is offline
Default Re: cb coax
From rear bumper.. Ran it under the truck alongside the brakelines up under the hood and through the firewall with the rest of the wiring harness..
If it gets drug out from under the truck I'm pretty sure the brake lines will get drug out too and I'll have much worse things to worry about than the coax..
Rob
Old 02-14-2008, 06:43 AM
Default Re: cb coax
Major Tom
Pull back the weatherstripping and you'll see two phillips head screws. Then there's two plastic snaps that hold it in from the front. The snaps release pretty easily so you shouldn't have to worry about breaking them.
Old 02-15-2008, 05:00 AM
Major Tom's Avatar
Default Re: cb coax
I think I may go with the under the truck along the frame and through the fire wall plan
Old 02-15-2008, 07:25 PM
Default Re: cb coax
There's an easier way if you're going to run it along the frame. Remove the sill plate and there is a hole where you can fish the cable into the frame rail.
Old 02-15-2008, 11:23 PM
Major Tom's Avatar
Post Re: cb coax
thanks this is getting easier and cleaner by the day.If I wait long enough someone will do it for me.Today it is -15 deg and I don't feel like crawling under the truck.
