02-08-2008, 07:31 PM
Windshield washers clogged
I had my driver's side windshield washer stop working last week. I called the dealer and they told me to brush the sprayer ports with soap and water. Despite my doubts, the technique worked like a charm. I guess dirt can build up and clog the ports (I run Prestone de-icer fluid in the reservoir so I knew that ice was not the issue). After brushing the ports, I sprayed lock lube/de-icer in them from the top side for good measure. I also now carry an old toothbrush in the truck as standard gear for on-the-road port scrubbing as needed.
02-09-2008, 12:14 AM
Re: Windshield washers clogged
Now only if that tech also knew how to get the rear wiper to clean more than just half of the window
08 H2 SUV slate blue lux pkg
06 H3 stealth blue adventure off road lights (SOLD)
02-09-2008, 01:17 AM
Save those old toothbrushes 1001 uses
02-10-2008, 01:13 AM
 I just wish I could get my wipers to clean the windshield when it is snowing or if the roads have a lot of ice melt from the snow. The snow just builds up and starts to freeze to the wipers.
I have had it get so bad I have had to pull off to the side of the road.
Is there anyone else with this problem or maybe having a cure for the problem other than moving South for the Winter?
whip2
02-10-2008, 02:36 AM
whip2
we ain't got no F***ing SNOW here...only grass, coke, horse, crack...
02-15-2008, 06:18 PM
Interesting - my wipers operate very poorly in certain winter conditions as well. And if I spray washer fluid onto the windshield, even de-icer fluid, it simply makes matters worse. Design flaw? Window? Wipers? It seems that there must be a signifiant amount of grime or snow on the windshield for the wipers to work properly - otherwise, the entire center portion of each side of the windshield is missed by the wiper.
02-16-2008, 01:36 AM
Mine work fine. Maybe you should replace em?
02-16-2008, 05:00 AM
Nah - they did it right off the bat when I bought them. I think they are the Bosch recommended versions.
