Old 02-11-2008, 06:04 AM
finall finall is offline
Default How many lube points on an H2?
Hi,
How many lube points are there on an H2? I can only find 10 on our 2006, but some say that there are 11-16?
Who knows for sure? I can find the tie rod ends (2), upper ball joints (2), idler arm (1), pitman arm (1), tie rod ends (2), and center link (2). That is 10 in total.
Are there any that I missed?
By the way, you do NOT have to remove the skid plate to get to any of these. Just turn the wheels to move the center link to either side. You also do NOT need a swivel lube fitting. Straight one work fine, as long as they are mounted on a flexible lube hose.
Help!
Old 02-11-2008, 05:10 PM
H2R's Avatar
H2R H2R is offline
H2R is on a distinguished road
Default Re: How many lube points on an H2?
This was sent before by some member. It should help
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
Old 02-11-2008, 08:08 PM
Thanks, but this diagram is not useful.
It shows 11 lube points, plus a 12th nonsense shot.
So where is the 11th zerk?
