Old 02-13-2008, 04:15 AM
Tex_h2's Avatar
Tex_h2 Tex_h2 is offline
Default Leak
I've got a small leak coming from somewhere around the drivers front tire. There is nothing leaking on the ground, but the wheel well is a bit on the wet side, and then today it started to burn off the engine and start to smoke a bit. Now, I have plenty of brake, coolant, oil and transmission.
Any Idea??
Old 02-14-2008, 01:26 AM
Tex_h2's Avatar
Default Re: Leak
The leak is a worn out filter for the Crankcase. 200.00 and your friendly dealersh_t!
Old 02-14-2008, 11:39 AM
Yetti Yetti is offline
Default Re: Leak
Crank case filter?????? I didn't think 6.0s had filters since they draw air from the main air duct of the air cleaner. the only filter I know of is the oil filter and they come with an oil change.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 02-19-2008, 07:28 AM
Tex_h2's Avatar
Default Re: Leak
Filter from the Front Differential replaced.
Get this
Filter : $8.66
1.2 Hours of Labour : $158.40
"shaking head" you got to love the dealership?
Old 02-19-2008, 07:32 AM
Default Re: Leak
Get this
Filter : $8.66
damn ! that's alot of $$$$ !!
