02-29-2008, 10:02 PM
'08 locking gas cap?
I've been trying to find a locking gas cap for an '08 H2. No one seems to have one that fits. I didn't really want to buy the whole locking fuel door again. I had the locking fuel door on the H3 just as a precaution. Has anyone had any luck with locking gas caps? Do you think it's even necessary? Thanks for any advice!
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
03-02-2008, 04:53 AM
Re: '08 locking gas cap?
For some reason, GM changed the fuel necks of the tanks from 07 up. I have not been able to find a locking cap either. I have the locking door on my truck just for a piece of mind. I am pretty certain there are tank baffles to prevent siphoning fuel out with a hose. On another note, I would like to have one for all those tree hugger Hummer haters around, I would not leave it unprotected!
2004 H2 Black, Chrome PKG, Luxury, HIDS, Pioneer AVIC D3 GPS, rear entertainment monitors, DVD player. Woofers to come...
2000 Corvette coupe, 6 speed, Ram-Air, underdrive pulleys, Nitto Extreme Radials.
1990 Saleen Hatchback #219 Vortech supercharged
03-02-2008, 05:18 AM
No wonder I can't find a locking cap.  I checked with the dealer and they said there's not much of a problem with people messing with the fuel tank. More of a problem in S. California are carjacked Escalades and H2's with Mexico so near.
03-03-2008, 01:55 AM
Thats the dumbest excuse for not making a locking cap that I've ever heard.
66' VETTE STINGRAY
07' Z06
03-25-2008, 08:06 AM
The first thing I changed was the gas cap when I bought my 08. I picked it up at pep boys here in bay area, ca. Its made by Stant, cant recall the part # but its identical fit, when you plan to change it out make sure you dont cut the plastic tether, wedge out the plastic ring that fits on the outside of the cap, this fits perfect on the new Stant cap.
Hope this helps..
03-26-2008, 12:35 AM
Hope this helps..
That's good to know, funny I called the dealership, and they still say there is no such thing!
03-26-2008, 01:12 AM
Hope this helps..
Thanks! I'll call PepBoys in the a.m. AGAIN! I called them when I had first posted my question and they said they didn't have one for the '08. Better idea, I'll just drive out and talk to someone there. I'm glad you mentioned the plastic tether! I didn't know you could wedge it out. Thanks for your info.
03-26-2008, 03:51 AM
The dealership will tell you that as there was never a locking cap released for the H2. The H3 has one as an export option only but not for the domestics. I am not overly familiar with the H2 fuel cap, but the standt cap, as long as it is the same thread should work just fine for your application. Standt makes a decent cap. And FWIW if you change it and start to see a check engine light, your first place to look would be the filler cap....
03-27-2008, 01:33 AM
I was bidding on a locking fuel cap for my h2 on ebay, supposed to fit ALL years. From these posts it looks like the 2007 and 2008 might be left out. Should I be weary of purchasing this cap that supposedly fits all years?
03-27-2008, 02:06 AM
Well, WikidPete said he had very good luck and a perfect fit with the Standt fuel cover from PepBoys. I didn't get to go over there yet. When I sopke to the parts mgr at my local Hummer dealer, he said a locking cap wasn't made for the '08. He said he has seen a couple of H2's come in with non-GM caps that didn't fit. He said they could be jimmied off quite easily by someone wanting to do damage. Do you have a PepBoys in your area? I'll try to check mine out tomorrow and keep WikidPete's positive experience in mind.
03-27-2008, 08:08 PM
no... not at all... your only issue that you might have would be the check engine light may come on if there is an issue surrounding the ability of that cap to seal.... so don't throw your old cap away for a few months anyhow.... (wait till the warm seasons first)
03-30-2008, 01:12 AM
I don't know about the '08, but I use a locking gas cap for my 2007 H2. The cap states that it is made for an H2 thru 2006 model year, but it fits the 2007 perfectly. I have been using it for a year, through the hot Las Vegas summer.
I found it at Checkers / partsamerica.com
It is listed as the Stant 11511
http://www.partsamerica.com/ProductD...rtNumber=11511
LAS VEGAS H2
2007 Victory Red LE H2
2005 Yellow H2 - Traded
2004 Victory Red LE H2 - Traded
03-30-2008, 05:17 PM
I'm wondering if there may be an issue with the early build date 07's vs later build dates. My 07 has a drastically different thread pitch on my factory cap than those for early model H2's. There is no way that a cap for an 06 will fit my filler neck. I checked into this after having the truck for one week and someone had already stolen my license plates. Have not had any further vandalism issues, so I quit looking for the new cap.
03-30-2008, 09:42 PM
Could be. My 2007 is mid-year limited edition.
LAS VEGAS H2
04-02-2008, 01:33 AM
WRONG!! GM has released a locking gas cap for the H2. Why would they not. Really?.......I have one. Part #10326376. I am sure they have one for the 08, if not the same part #.
The thread pitch on the 06 non-LE SUV and 07 LE SUV locking gas caps must be identical. Same one fits both our 06 and now 07.
Get the OEM locking gas cap from the dealer, and quit messing around with aftermarket gas caps. None are as good as what you get from the dealer. If your aftermarket fails or is the wrong one, any damage to gas tank (like imploding due to vacuum) is not covered. It happens often.
The OEM one costs as much as a drive around the block in your H2, so why not get that one?
04-02-2008, 02:22 AM
Finall,
As you proved in your query into the part number for the cigarette lighter plug, not all dealerships are intelligent enough to be able to find the correct part number. Thanks for posting what has worked for you. Upon inspection of an 06 factory gas cap versus my 07, the thread pitch is quite different. I may try the 06 number the next time I am near the dealer, let them try to install so if they strip the filler neck, they can pay to replace. The trip back to my dealer is around the block, only 300 miles each way.
04-02-2008, 03:14 AM
04-03-2008, 02:30 AM
Thanks for the photos. My factory cap looks the same as the photos, but every aftermarket cap I had found was threaded. Anyhow, it looks like I will have to make a trip to the dealership anyway...my door bucket is cracked from the key hole to the edge. In addition, my factory chrome gas cap was bubbling/pitting and I was waiting on service or something more significant before making the trek. I will have to look into the factory locking cap when I am there.
04-03-2008, 05:43 PM
