Old 03-06-2008, 01:51 AM
Tornadough Tornadough is offline
Tornadough is on a distinguished road
Default Optimum PSI?
If you have aftermarket wheels/tires do you still follow the door jam PSI ratings?
I've been running 325/50 Nitto Terra Grappler Tires for over 2 years. When I first put them on I hated the feel. So I upped the tire pressure and the handling/ride seemed to improve.
I also went from the stock 17s" to 22s" and they're waaaay heavier. Not sure if that has anything to do with it.
I did some research on this site and it seems most people recommend 35-40 PSI regardless of tire size. So is running at the max tire rated 60 PSI bad in anyway?
