Old 01-03-2006, 11:52 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
As soon as it arrives I'm swapping out my base radio with a OEM 6 disc with XM that I bought from a member here. my question is, if by chance the radio enables the security when I install it, how do I unlock it without taking it to the dealer? The dealer said it would cost about $50 to unlock it if it should happen. they said they haven't had any come in yet. Thoughts?
____________________________
Mike E's Avatar
Old 01-04-2006, 12:09 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Mike E:
As soon as it arrives I'm swapping out my base radio with a OEM 6 disc with XM that I bought from a member here. my question is, if by chance the radio enables the security when I install it, how do I unlock it without taking it to the dealer? The dealer said it would cost about $50 to unlock it if it should happen. they said they haven't had any come in yet. Thoughts? </div></BLOCKQUOTE>
You have to got to the dealer anyway to program the radio to the internal LAN system in the vehicle.
The security system on the H3 for the radio is the VIN number of the vehicle. When the radio is powered up, it compares the VIN supplied from the BCM, via the class 2 serial data link, with the internal VIN it was coded with. If they don't match, the radio will lock. the only way to unlock is to program the new VIN into the radio with a TECH 2.
This also applies to the XM receiver. So they both have to have the new VINs programmed into them in order to operate in the new vehicle.
Old 01-04-2006, 12:23 AM
kodiakz kodiakz is offline
kodiakz is off the scale
Mike E, f5fstop is correct--plan on taking it into the dealer to have it programmed on the tech II. If it was in another vehicle, there is 0 chance that it will work when powered up--it will display "locked".
Old 01-04-2006, 02:13 AM
Mike E's Avatar
Thanks guys! Can I go ahead and install it and then take it to the dealer? It just wont work until they fix it, correct?
Old 01-04-2006, 03:16 AM
Absolutely. It will go in fine, it will just say locked and do nothing until it relearns the new vin. The programming only takes about 5 mins as I just did a nav the same way today.
