10-20-2005, 04:14 AM
Hi all,
I just put in a TrueFlow direct filter replace, and the Check engine light came on. I disconnected the battery ground wire for about an hour the light stay on. So i disconnected again all night. The light was gone but came back 10 min. later. The H2 drives really bad it would hestitate . Anybody had this same problem after install a new intake or direct replace filter. Please HELP
05 Lux Suv
95 Ducati 916
Hi all,
05 Lux Suv
95 Ducati 916
10-20-2005, 04:35 AM
\'05 SUT
10-20-2005, 04:39 AM
Thank for the quick respone. I will check the filter I installed right out of the box it was pre-oiled.
05 Lux Suv
95 Ducati 916
10-20-2005, 04:41 AM
Well, let's see how relevant the offered answer is.
That's the danger of posting late at night -- only the loons are around.
\'05 SUT
10-20-2005, 05:04 AM
Hahha one's better than no one
05 Lux Suv
95 Ducati 916
10-20-2005, 02:49 PM
I just installed the Tru Flow too and it was soaking in oil in the bag! I used paper towels to soak it up and then installed it. Even after that I have some oil that has puddled below the filter! It will definitely throw a code. Just get some carb cleaner and clean off the wires in the MAF sensor and you should be o.k.
1994 Chev Suburban Blown
10-21-2005, 04:58 AM
Thanks for all the responses, I took the filter out and soaked up the oil and clean and wipe the MAF. That fixed it. One questin about cleaning the MAF with carb cleaner, do you just spray it directly into the MAf??
05 Lux Suv
95 Ducati 916
10-21-2005, 05:02 AM
H2 Bill,
Do you just have the Trueflow filter or the intake tube too. Look for the intake tube but can't find it for TrueFlow. The Airaid is not completely round it's flatten out at the end.
05 Lux Suv
95 Ducati 916
10-21-2005, 01:00 PM
I was going to suggest checking the engine, but it sounds like you have it figured out.
10-21-2005, 03:03 PM
Nixxxster I hve the AirRaid tube and it all works fine. No problem at all with fit.
