Old 12-23-2003, 09:35 PM
Patriot Patriot is offline
Patriot is off the scale
Well, I took my H2 in for some minor things..one of them being a slight groan in the steering when you turned at slow speeds. I thought is was a lube problem with the cold weather. Turns out it was the steering pump. Apparently, they are a problem on many GM trucks.
On the good side, they fixed the rattle in the visor/pillar area. TSB had them add some strips in the pillars...seems better...BUT now because I can't hear that rattle any more, I hear a new on in the rear...sheesh.
Oh...they also said they are working on the "clunk" issues at H2 central. Adding the grease on the splines works but only for about a month...then the sound returns. I think someone else here on the forum said they tried that?? Anyway, they said that a true fix may be out soon??? We can only hope.
