Old 03-25-2008, 12:12 AM
Default Got Warrior Products Shackles On... Nice!
After some good info from Sewie and other research decided on www.warriorproducts.com for stock lift. Chose the WP150 product. They sell these for Jeeps but like Sewie and others have pointed out they have a superior product that priced right. This shackle measures up as follows. I wanted a stock lift for the back of my H3...
Stock Shackle Warrior Products Difference
overall length 6" 6 3/4 " +3/4"
center hole to
center hole 3.5" 5" +1.5"
Lift in back when done ON MY RIG W/35" TIRES
36 3/4 to 37 " 371/2 to 37 3/4" +1/2 to 3/4"
Im going to attach some pictures behind this...
Old 03-25-2008, 12:16 AM
Default Re: Got Warrior Products Shackles On... Nice!
Heres a comparison of shackles
Old 03-25-2008, 12:18 AM
Used 2 jacks to do it...
Old 03-25-2008, 12:20 AM
Wound up using small jack to help spring extend. Rather than move differential...
Old 03-25-2008, 12:22 AM
Stock Shock showing + measurement exposure other elements are happy...
Old 03-25-2008, 12:25 AM
New & better profile...
Thats all Folks!!
Old 03-25-2008, 12:36 AM
Just a final note. There are other ways to install the shackles that are probably safer than what I showed here.
I will say that the quality of the warrior product was great. All the hardware was included and directions. The bolts fit well and the nuts were the locking type so they wont shake off. I recomend them highly.
WWW.WarriorProducts.com
Thanks for all the other usefull posts from other on shackles that were a big help when questions arose! Sewie and HumBebe to name a few...
Old 03-25-2008, 03:13 AM
tomp's Avatar
tomp tomp is offline
I am finding your numbers above hard to understand. So how much did it raise the rear total?
Old 03-25-2008, 11:10 AM
Settled in Little better than 1/2" after a few.
Old 03-26-2008, 04:51 PM
Jason @ Warrior Jason @ Warrior is offline
Jason @ Warrior is on a distinguished road
Woody,
Thank you for your kind words and very helpful information.
We've decided to go ahead and add part numbers to our product line specifically for the H3. We have two shackles available, in two finishes, totaling 4 part numbers. Note that these part #'s rate these heights, but they may vary slightly, just because of the uncontrollable factors like spring wear.
1. Part #154 - Hummer H3 0.5" Lift Shackle - Powder Coated Hammertone Grey
2. Part #354 - Hummer H3 0.5" Lift Shackle - Gold Zinc Plated
3. Part #128 - Hummer H3 1.25" Lift Shackle - Powder Coated Hammertone Grey
4. Part #328 - Hummer H3 1.25" Lift Shackle - Gold Zinc Plated
If you could, can you send me in email some larger versions of the pictures you posted? We'd like to get a press release out and get some of our dealers to start listing these parts so they're more accessible to you guys.
Two more questions: What models years has the H3 run so far, so that I can get that information out too? Also, what rear axle is in this SUV?
Jason Roy
Warrior Products
Old 03-27-2008, 12:14 PM
Originally Posted by Jason @ Warrior
Woody,
Jason,
Your welcome.
Glad to hear that warrior products is taking the initiative to offer products to the Hummer H3 community.
We H3 owners find it frustrating at times looking at all the aftermarket products out there. Then wondering if they adapt to our needs
Sending you a PM
J
If you could there are some other items/products that we would like to see offerd. Maybe your design folks could develop a rack that sits over the spare tire in the back!
Thanks for looking
Old 03-27-2008, 06:42 PM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
Woody,
Hey I see you guys are in Tualitin. I live in Vancouver and have an '06, and would be happy to use my H3 as a test mule if you plan on fabbing anything up. Other than a dent in the p/s front door, a trashed rear plastic piece, cracked windshield and tons of trail rash, it would make a great truck for advertising pictures when you fab me up some rock rails, UCP, and a rear tire rack
Old 03-27-2008, 07:05 PM
Email me your contact information, there may be some stuff we can work together on for those kinds of projects.
We stay mainly Jeep, but the boss may consider some truck stuff too.
jason at warriorproducts dot com
Jason Roy
Warrior Products
Old 03-27-2008, 10:14 PM
6pack 6pack is offline
6pack is an unknown quantity at this point
Damn, wish I would have thought of that. I just muscled it down with a breaker bar. Your way looks easier.
2007 H3 Lux/Adv 5 speed, Gibson Extreme Duals cat-back, K&N FIPK, PCMforless tune, SAW torsion bars, Samco Shackles, Fox Racing shocks, Trail Duty Bump Stops, 35" ProComp Xterrain tires w/Tactical Rims, Gobi Stealth Rack
Old 03-29-2008, 05:04 PM
Started trying the same way with a bar. The bottle jack fit in nicely and with just a little hand work easily moved out the leaf spring and held it in place. Without knuckle busting. Especially on the driver side where the exhaust pipe left little room for slack...
Old 03-30-2008, 01:50 AM
Goonsqd's Avatar
Goonsqd Goonsqd is offline
Goonsqd is on a distinguished road
Hey!!! I'm in Vancouver too....
Mine doesn't have all the damage evl's does. Sorry! LOL....oh and it's an 07'
2006 H2 SUV, 2007 H3 Adv Pkg
Old 04-01-2008, 01:13 AM
Jason,
Great news. I put your shackles on a couple months ago and I just received a set of your shock conversion mounts. Hopefully you guys will come up with some new stuff for us, or at least cross-reference some of your existing products that will fit.
Old 04-01-2008, 04:49 AM
H3slate's Avatar
H3slate H3slate is offline
Originally Posted by Sewie
Jason,
I emailed Jason about being a test H3 for them, and he said it would be a ways out before they could consider making H3 accessories. Hopefully sooner than later.
Did you get different rear shock mounts? Did the rocky road ones not work out?
Old 04-01-2008, 07:01 AM
I actually swapped out to the JKS ones (they arrived before the Warrior ones). They require a little filing of the mounting holes to fit though. The RR ones are okay and will work fine, but I wanted to get some of the up travel back.
Old 04-01-2008, 04:04 PM
You guys might also look into whether or not any of our HD cross pins work. They're a great upgrade for the bar pin end of your shock...the usual pressed tube versions rust out and break if you're in a part of the country that is rust prone.
Here are a couple links to the cross pins. RJR is a good online dealer for us. I'll shoot them an email today and tell them to make the new shackle part #'s available online.
http://www.rjroffroad.com/warrior-sh...-pr-16827.html
http://www.rjroffroad.com/warrior-sh...-pr-16828.html
Jason Roy
Warrior Products
