Old 03-30-2008, 08:04 PM
Lex_Ordo
Default Warn Multimount Hitch???
Has anyone used one of these in the rear receiver, of their H3?
Seems like it would be a real easy solution to wanting a hitch and not having to completeley disassemble and replace the front bumper.
I suppose a Snatch block or Two might be neccessary, and where does the the power come from? Leads that manually attach and run back to the battery?
Any thoughts or user experience would be appreciated.
Old 03-30-2008, 08:38 PM
Default Re: Warn Multimount Hitch???
Sounds interesting. Is there enough amperage without running a real big gauge wire back to get what you need?
Any Pics?
Old 03-30-2008, 10:04 PM
Vettster Vettster is offline
Warn sells a kit which consists of a solenoid, switch and sufficient cable to wire up to the front (as on the H2) as well as the rear receiver.
The solenoid is so that the cables are not energized all of the time just in case they short out.
Old 03-30-2008, 10:23 PM
fourfourto's Avatar
Any Pics?
I ran a 10 gauge wire to the back trailer plug.
Could I use that wire to power a rear winch(I was thinking a cheap 8000lb),it would be handy to plug it in there .
