Old 04-03-2008, 01:21 AM
kalantar kalantar is offline
kalantar is off the scale
Default difficulty installing a light bar
How hard is it to install a light bar without the wiring harness that came with it? Is it basically 2 wires with an on and off switch?
I found a used one for sale but it doesnt come with the harness.
Thanks!
Old 04-03-2008, 09:28 PM
Rene S. Nielsen Rene S. Nielsen is offline
Rene S. Nielsen is off the scale
Default Re: difficulty installing a light bar
Hi
I bought one just like it, it's really no problem.
One mine there where 3 wires 2 positive and one ground.
One positive for the 2 inner lights on the light bar, and another for the 2 outer lights.
I just wired these 2 positive together with a single one using a bigger gauge (hope this is spelled right).
And then I put a reley on it with a on/off switch.
The biggest problem was to get the big gauge positive all the way out to the battery.
Best regards
Rene
Old 04-03-2008, 10:38 PM
Vettster Vettster is offline
If you have the factory harness, it's plug and play.
All you have to do is drill a hole for the switch in the overhead console.
The part number for the kit (including the lights) is 89006865.
I bet some savy parts man could come up with the component part numbers.
Old 04-03-2008, 10:50 PM
Thanks, so the wiring isnt too complicated
How do you connect the wiring, you dont drill a hole in the roof?
Old 04-04-2008, 01:54 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
If you get the factory harness, the wiring is already through the gromet, like Vettester said, plug & play.
Old 04-04-2008, 03:21 AM
Called 3 dealers today, no one carried it. Talked to a few members here and they said it wasnt worth the trouble.
Decided to go with a custom one or possibly the Delta.
Old 04-04-2008, 07:12 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Heres the factory schematics, you can build a harness from these
Old 04-04-2008, 07:13 PM
HUMTECH's Avatar
Old 10-26-2008, 08:40 PM
axxense axxense is offline
axxense is on a distinguished road
Check this out - it may help - http://www.axxense.com/Lightbar/H2_L...ructions_2.pdf
The lights pull a lot of current - usually way too much for a dash or overhead console mounted switch - this is why you want relays. The switch trips the relay, which, in turn, turns on the lights, thus handling the high current draw.
