Old 04-04-2008, 01:05 AM
WikidPete WikidPete is offline
WikidPete is off the scale
Default 2008 H2 - Strange Encounter
Ok so a little background on this. I've had my H2 for about 9 months and it has approx 10k miles and still love it even with this weird encounter.
So I took a trip from Northern California to Arizona to pick up my military 3/4 ton trailer from the USMC Station in Arizona. I was towing the uhaul Auto trailer to load the 3/4 ton military trailer. As I was driving down I5 in the middle of the night I started encountering this weird issue. The speedometer kept fluctuating and the transmission seemed like it was stuck in 2nd gear, every warning light came on. This all happened all of the sudden like it was possessed. Pulled over stopped and restarted the car again thinking it will reset the computer.. Yet it felt like the transmission was stuck and wouldn?t switch gear as I speed up. Some of the warning light went out but a few still stayed on. I called onstar to find out what options I had being stuck in the middle of nowhere towing an empty trailer. They said that I need to bring it to the nearest Dealer.
So I?m trying to figure out what to do and it?s like 2am in the morning by now. I decided to try limping along the highway to the nearest exit and low and behold the transmission was switching gears fine again. I kept it under close watch as I continued my trip to AZ at this point the only error light was the check engine light. I kept checking everything after each gas stop and didn?t seem to see any weird issues.. As I got closer to Arizona the check engine light suddenly disappeared during one of the gas stops. The trip back I encountered no issues, like it never happened.
The only thing I did notice was the Transmission was running around 175F and at one point it hit 200F.
Sorry for the lengthy post.. Any of you guys encounter anything strange like this? I?m taking it in next week for them to check it out. I asked if they can pull the error codes from On-Star. They say that they can?t. That is weird..
Anyways still a great Truck!!
Old 04-04-2008, 01:38 AM
mikejr's Avatar
mikejr mikejr is offline
Default Re: 2008 H2 - Strange Encounter
OK...sounds like a similar issue my dad had with his 08 SUV. He was stuck in gear etc. Sounds electrical to me.
When I first got my 08 SUV I had issues with dash lights, locker indicator etc...all due to a chaffed wire which screwed up the BCM.
Now the said they couldnt find anything wrong with my dads truck, had it for a week and took everything apart and even consulted with the hummer engineering team. They thought that maybe taking things apart and putting them back together might have fixed it.
Again...i think its electrical. Everything is run by computers on these things.
2009 H2 Silver Ice LE
Old 04-04-2008, 02:26 PM
CONRAD II's Avatar
It sounds like the same problem I had. If I remember correctly there is something in the ignition that needs to be replaced or fixed. BTW the problem will continue untill you get it fixed.
66' VETTE STINGRAY
07' Z06
Old 04-04-2008, 04:12 PM
Vettster Vettster is offline
Onstar sucks!
How could they let you drive the vehicle when it was acting like that?
A dying/not shifting vehicle is obviously a safety hazard.
I didn't even activate my "free" year. And when it was over they had the balls to send me a bill for the subsequent year.
Old 04-04-2008, 04:31 PM
pdxhummerguy's Avatar
pdxhummerguy pdxhummerguy is offline
pdxhummerguy is on a distinguished road
I had the same problem. It was the ignition.
Old 04-04-2008, 04:48 PM
WHOSNEXT's Avatar
WHOSNEXT WHOSNEXT is offline
ditto
Old 04-04-2008, 06:23 PM
Thanks for the info everyone, I'm going to let the tech know next week about the ignition.. Do you guys know what part was replaced to fix the issue, in case I have to let the tech know.. I feel better now that I was not the only one.
Old 04-04-2008, 06:30 PM
Yeah I asked them where the closest Hummer dealer was and they said LA.. I was still 200 miles away.. LOL. And I think the only time I use it is when there is an issue.. and they always say take it into the dealer. Anyone else get any good use out of it?
Originally Posted by Vettster
Onstar sucks!
Old 04-04-2008, 07:22 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Def ignition switch, common. Ign 1 power runs through the ign switch to the transmission control module, the switch fails and the transmission goes into limp mode. Usually accompanied by 5 trans codes, any gm tech should be familar with this and there is a tsb on it as well.
Old 04-04-2008, 08:01 PM
BigPoppa1411's Avatar
I havent had to use it for any mechanical issues, but they were great when it came to getting help for 2 vehicle accidents I came upon on my way home. I live out in the boonies and there isnt much traffic on my road late at night so it was helpful.
Old 04-05-2008, 03:46 AM
clinecs clinecs is offline
clinecs is on a distinguished road
I have an 08 H2 w/ all the problems listed above but a lot more severe. I just got it out of the shop Monday and it just broke down on me again on my way home tonight. This time it wouldn't shift out of 2nd, several warnings lights came on, and the mph needle was going crazy. I have only had mine for about 5months with only 7k miles and am on my 2nd tow and 3 trips(was able to limp it in myself on one of the trips) to the dealer. I am beyond frustrated at this point.....not sure what to do. Local dealer keeps saying the fixed it because they found some some wires chaffed and they replaced them. This sucks!!!
Old 04-06-2008, 03:21 AM
BigBlue's Avatar
BigBlue BigBlue is offline
BigBlue is on a distinguished road
Yeah... I just finished my GM buyback as a result of this problem... by the time they had figured out that it was a Transmission Control Module (which is what your problem likely is) they had taken apart so much of the truck that it never went back together right.
http://www.elcovaforums.com/forums/s...major+problems
That's the thread I posted it all in.
Sorry to hear it!
2008 H2 SUT Adventure series "Tactical Edition" ordered 8/8/2007. Delivered 10/11/2007, GM Bought back on 11/28/2007 and took delivery of replacement 4/3/2008... GM made everything right.
Black/Black/Black 24" Mazzi Hulk Wheels, Custom Powdercoated Tire Carrier Eliminator and Fuel Door, AVIC-f90BT and every add-on available, SWI and Onstar interface. SR7/ZR3 Radar Defense System. Amp Research/Bestop Powersteps. Llumar 5% Tint. Heads-Up display.
Old 04-06-2008, 04:00 PM
I will be sure to follow up w/ my service guy tomorrow morning about this ignition switch. I don't think they really have a clue what to do....all they keep saying is that they find chaffed wires and replace them....
Old 04-09-2008, 05:44 PM
H2 Bill H2 Bill is offline
Make sure that you only have the key and fob on the keyring. The weight of alot of other keys can screw up your ignition switch.
1994 Chev Suburban Blown
Old 04-10-2008, 12:10 AM
so I dropped the car off this morning... and picking it up today.. dealer called and said that my 08 has the latest Ignition Switch and there is nothing more to do since the problem is not showing up. Any suggestions from you guys? I hate to get stuck again when I go on a long trip.
Old 04-11-2008, 05:23 PM
pdsq99f4 pdsq99f4 is offline
The 08 is different than the previous years. Have them check the connector at the transmission. The one I had that did something similar had a poor connection at the trans. This vehicle would also cycle the locks when the problem occured because the vehicle thought it was shifting out of drive.
Old 04-15-2008, 06:18 PM
pteam's Avatar
pteam pteam is offline
pteam is on a distinguished road
Well I have to say my 08 h2 is running really good ::knocks on wood:: . I did have one major problem coming back from a road trip with family at 2am the car overheated, well almost I had my eye on it and pulled over before. Seems the rear AC unit's coolant line was loose and was leaking coolant only when the rear AC was on and left me stranded. Got it back and everything has been good since then.
It does seem like there is a quality control issue going on with this many problems on brand new h2s.
My cars:
Lamborghini Murcielago
Supercharged Viper 800 HP Special Edition #49 of 50
Porsche Boxster S
My Hummers:
08 H2, 22 in rims, 6 HID lights, 20 in TV with DVD
4 H2 limos 3 have lighted dance floors + ceilings, 1 has Zebra interior 24-26 passengers
H2 Limo 26 pass lighted dance floor (sold)
H2 Limo 24 pass (sold)
03 H2 (sold)
H1 Open top (sold)
FirstClassLimos.net - H2 limos and party buses in OH & PA
my car collection
Old 04-15-2008, 08:22 PM
Old 04-18-2008, 12:46 PM
3Hummer's Avatar
3Hummer 3Hummer is offline
haha after this strange encounter title, and the start of driving down i-5 at night i thought you were gonna say you came across something like big foot haha, anyway no advice on this issue im an h3 owner, but i hope you get this taken care of
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 04-18-2008, 08:44 PM
Hmmm2's Avatar
Hmmm2 Hmmm2 is offline
LOL .. I was thinking the same thing at first. Anything is possible just around Coalinga on the I-5 in the dead of night .. just passing Harris Ranch, inhaling all of those wonderful bovine fumes.
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
