Old 04-04-2008, 02:33 AM
alex7296 alex7296 is offline
alex7296 is on a distinguished road
Default Wheels, disconnecting CTIS
When you disconnect the CTIS lines to use non CTIS rims what is the best way to do it. Remove the lines from the hub assembly or from the rim. If you remove the lines from the rim do you leave them coiled in the center caps?
2002 H1
2006 H2
1970 Chevelle Drag Car
1954 Ford
1979 Trans am
Old 04-04-2008, 01:17 PM
phazer42 phazer42 is offline
phazer42 is on a distinguished road
Default Re: Wheels, disconnecting CTIS
If you are using a seperate wheel / tire assembly to install to your truck. Get a plug, I believe its a 1/4" pipe thread and can be found at any hardware store for the hub. Then leave the CTIS on the wheels you are taking off and install the new ones. If you don't use the plug you will get stuff in the air lines causing you problems later. Just remember to install some thread sealer / tape to the plug prior to instilation.
