Old 04-05-2008, 01:18 AM
porschett's Avatar
Default Auxillary Lighting
O.K., got 2 sets of PIAA's mounted on the grill guard, wires run into the engine compartment, relays, switches in hand; where do I go from here? I know I'm supposed to hook up the main hot from the relays to the battery, and of course, the ground to a good ground. Duhhh!
My question is where do you hook up the power to the switch. Is there anywhere inside that's good? I'd like too install the switches in the overhead console. How about the relays. Any tips you all can supply would be appreciated.
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
Old 04-05-2008, 02:47 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Auxillary Lighting
Old 04-05-2008, 02:49 AM
HUMTECH's Avatar
There are ign power terminals in the under dash fuse block
Old 10-26-2008, 08:34 PM
axxense axxense is offline
axxense is on a distinguished road
Hi. Check this out http://www.axxense.com/Lightbar/H2_L...ructions_2.pdf.
By the way, I cut a hole in the blank space underneath the rear window wiper switch and installed the switch for the lights there.
Hope it helps.
